EoMPLS with Redundandancy using Service instance
Nuhu_20071
 hello every one ,
Please check attached document ....Our requirement is
Requirement :   Drop tagged data (200,300,400) coming from ASR9000 to respective ASR920 (a,b,c) respectively by using EoMPLS L2VPN  .
Configuration Steps:
1)  Service instance  are created on ASR 907 ,as Router ASR 907 will see vlan tag attached and will send to   respective instance configured on ASR 920 , Service instance are created on destination ASR920 respectively .
2) Uplink on ASR 9000 toward ASR907 is configured as sub interface with Vlan 200,300,400 .
3) Loopback are configured on each ASR .
4) IGP (OSPF with MPLS LDP is configured between internal Ring from 920a to 920c).
4) Configuration on ASR 907 a and ASR 907 b for Service instance are
ASR907a> enable
ASR907a# configure terminal
ASR907a (config)#interface TenGigabitEthernet 0/0/0
ASR907a(config)#description **Connected to ASR9K**
ASR907a (config-if)#no ip address
ASR907a (config-if)#no shut
ASR907a (config-if)# service instance 200 ethernet
ASR907a (config-if-srv)# encapsulation dot1q 200
ASR907a (config-if-srv)# xconnect 10.10.10.2 200 encapsulation mpls
ASR907a (config)# exit
ASR907a (config-if)# service instance 300 ethernet
ASR907a (config-if-srv)# encapsulation dot1q 300
ASR907a (config-if-srv)# xconnect 10.10.10.3 300 encapsulation mpls
ASR907a (config)# service instance 400 ethernet
ASR907a (config-if-srv)# encapsulation dot1q 400
ASR907a (config-if-srv)# xconnect 10.10.10.4 400 encapsulation mpls
same on ASR 907b
 Configuration Steps on ASR 920 a,   are
ASR920a (config)#interface gigabitethernet 0/0/2
ASR920a (config)#description **Connected to CE Node**
ASR920a (config-if)#no ip address
ASR920a (config-if)#no shut
ASR920a (config-if)# service instance 200 ethernet
ASR920a (config-if-srv)# encapsulation dot1q 200
ASR920a (config-if-srv)# xconnect 10.10.10.1 200 encapsulation mpls
ASR920a (config)# backup peer 10.10.10.5 200 pw-class pw1
ASR920a (config)# backup delay 5
ASR920a (config)# exit
Configuration Steps on ASR 920 b for EoMPLS L2 VPN
ASR920b(config)# pseudowire-class pw1
ASR920b(config-pw-class)# encapsulation mpls
ASR920b(config)# backup delay 0 10
ASR920b (config)#interface gigabitethernet 0/0/1
ASR920b (config)#description **Connected to CE Node**
ASR920b (config-if)#no ip address
ASR920b (config-if)#no shut
ASR920b (config-if)# service instance 300 ethernet
ASR920b (config-if-srv)# encapsulation dot1q 300
ASR920b (config-if-srv)# xconnect 10.10.10.1 300 encapsulation mpls
ASR920b (config)# backup peer 10.10.10.5 300 pw-class pw1
ASR920b (config)# backup delay 5
ASR920b (config)# exit
Configuration Steps on ASR 920 c for EoMPLS L2 VPN
ASR920c(config)# pseudowire-class pw1
ASR920c(config-pw-class)# encapsulation mpls
ASR920c(config)# backup delay 0 10
ASR920c (config)#interface gigabitethernet 0/0/0
ASR920c (config)#description **Connected to CE Node**
ASR920c (config-if)#no ip address
ASR920c (config-if)#no shut
ASR920c (config-if)# service instance 400 ethernet
ASR920c (config-if-srv)# encapsulation dot1q 400
ASR920c (config-if-srv)# xconnect 10.10.10.1 400 encapsulation mpls
ASR920c (config)# backup peer 10.10.10.5 400 pw-class pw1
ASR920c (config)# backup delay 5
ASR920c (config)# exit
Confusion point : Do I need to add "rewrite ingress tag pop 1 symmetric"
Please check and reply ......your prompt guide will be appreciated.
Best Regards
NUHU
Nuhu_20071
Waiting for reply .............
