Equivalent Config for T1 Module
rsinghnyc
Community Member
I am in the process of replacing an Adtran NetVanta 3200 Router with a Cisco 1751. The 1751 has a 1DSU T1 WIC.
Here are the statements for the NetVanta regarding it's T1 WIC:
interface t1 1/1
tdm-group 1 timeslots 1-24 speed 64
no shutdown
interface fr 1 point-to-point
frame-relay lmi-type ansi
no shutdown
cross-connect 1 t1 1/1 1 frame-relay 1
interface fr 1.500 point-to-point
frame-relay interface-dlci 500
ip address xxx.xxx.xxx.xxx 255.255.255.xxx
Can someone please provide me with some guidance as to the equivalent statements on the 1751 Router?
royalblues
Level 11
Level 11
here you go for the 1DSU T1
interface Serial0/0
bandwidth 1536
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-24
interface Serial0/1/0.1 point-to-point
ip address x.x.x.x y.y.y.y
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a0080093c56.shtml
Narayan
royalblues
Level 11
Level 11
interface Serial0/0
bandwidth 1536
no ip address
Narayan
I have added the statements above, and the configuration works. Thank you.
