Equivalent model for WS-C2960-48TT-L and WS-C2960-24TC-L
subarayarsooper
Please tell the equivalent models for WS-C2960-48TT-L and WS-C2960-24TC-L respectively.
@subarayarsooper yes. but those models are also EOL. now you can use C1000 series.
Good luck
KB
5 Replies 5
C1000-48T-4G-L and C1000-24T-4G-L
Good luck
KB
Hey thanks for the reply but in the cisco suggested replacement product it shows WS-C2960+24TC-L and WS-C2960+48TC-L. But the 2960 series is being announced EOL.
So need some clarification
where did you see that Cisco suggest the WS-C2960+24TC-L and WS-C2960+48TC-L as replacement options ?
Check the datasheet linked below, it coincides with what @Kasun Bandara says.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-plus-series-switches/eos-eol-notice-c51-744423.html#Productpartnumbers
Good luck
KB
Leo Laohoo
If all that is needed is a simple Layer 2 switch (and nothing else), Catalyst 1000 is appropriate for this sort of task.
