Equivalent throughput from 2 or 3 switches C3650 stack membes
Isaias1010
Hi everyone
We were just trying to understand, what´d be the total switching throughput capacity by using only 2 members of switches on a stack?
What would be for 3 switch members?
As per documentation, Cisco says that we can stack up to 9 switches (lets say 9x WS-C3650-48PQ ) an you will get about 160 Gbps non-blocking as per its Cisco StackWise-160 technology.
How can we calculate total throughput from certain numbers of members ?
thanks!
Reza Sharifi
See table-7 in the datasheet for switching capacity per model.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet-c78-729449.html
BTW, if you are planning to purchase new switches, the 3650 series is end-of-life. So, you may want to look at the 9300 series.
 On this link you can see a detailed explanation but, unfortunatelly is for 9200, wihich is the new 3650. Maybe you can have an idea.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-stackwise-architecture-cte-en.html
