Erased nvram
Ed Lo
I'm using a 1941w router and the default gatway to access the gui through a browser is 10.10.10.1 . As I'm new at using it I was learning how to do things and so to make things go back to normal I looked at how to reset and erased the nvram. Now when I connect an ethernet cable to get to the gui it does not connect. Is there anyway I can return this to normal?
Thank you
Reza Sharifi
You basically erased the config.  Now you need a console cable to logon to the device via the console port and put the IP address back (10.10.10.1), so you can access it via gui.
Would the IP address be put on the the configuration of the Ethernet port?
Yes, assign the same IP to the same interface, so you can logon to it via gui.
Also, make sure ip http server is configured on the device.
