err-disabled switch port
rsamuel708
I have several ports on my network that I continue to see go into an err-disabled state when devices are connected to the network jack. I can fix these by doing a shut/no shut on the port, but I'm not sure what's causing this to happen?
No speed/duplex mismatches which has been the normal cause, so what else can cause this to happen? bad ethernet cables?
Thanks in advance.
/rls
6 Replies 6
Giuseppe Larosa
Hello Robert,
if you have logging enabled examine the log there should be a message for this.
possible causes include:
port security
STP BPDUguard
and probably also port flapping (this can be caused by cabling)
5 up/down in 1 sec can trigger port flapping.
if the port just disabled is x/y
use
sh log | inc x/y
Hope to help
Giuseppe
I do see the port flapping error, but I'm not sure how that could be caused by cabling. Could you explain a little more?
Thanks.
/rls
Hello Robert,
flapping is defined as frequent up/downs on the port for this I thought of a relationship with cabling issues (an intermittent link/wire in the RJ-45)
there is also an open issue about flapping on C2950 it is a bug.
We found it for frequent deregistration of VOIP phones caused by these up/downs
We tried last available IOS for C2950 but it didn't solve.
Hope to help
Giuseppe
Thanks Giuseppe, so you think the cables could have some physical problems that cause the port to flap, and then go into err-disable mode? All of the switches are newer 3750s.
/rls
Leo Laohoo
UDLS Port Aggressive can also cause a port to go into err-disable.
Eric Kenny
You can set the switch to automatically recover from an error disabled state, that way you don't have to waste your time logging in to the switch and shut/noshutting the port.
See here: http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml#topicsub1
