Error after slave switch replacement - %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529
alfen
Visitor
Hi guys.
We replaced a slave switch recently and error messages appear only after we connect the tenG fiber and 1 utp.   Prior to the replacement there was no such errors.
I searched online and it seems like my problem is similar to Bug ID: CSCty07602 but I am using version 15.0(1)SE3 that should be a fixed version.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtt42626
------------------ show version ------------------
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(1)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 30-May-12 13:41 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWARE (fc1)
B1-1-ADM-R18-3750-S01 uptime is 1 year, 22 weeks, 3 days, 2 hours, 59 minutes
System restarted at 11:28:38 SGT Fri Jun 8 2012
System image file is "flash:/c3750e-universalk9-mz.150-1.SE3/c3750e-universalk9-mz.150-1.SE3.bin"
Errors
097029: 000055: Nov 11 16:22:31: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1456 (B1-1-ADM-R18-3750-S01-2)
097030: 000056: Nov 11 16:22:36: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1456 (B1-1-ADM-R18-3750-S01-2)
097031: 000057: Nov 11 16:26:10: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1444 (B1-1-ADM-R18-3750-S01-2)
097032: 000058: Nov 11 16:26:15: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1444 (B1-1-ADM-R18-3750-S01-2)
097033: 000059: Nov 11 17:06:08: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 60 (B1-1-ADM-R18-3750-S01-2)
097034: 000060: Nov 11 17:06:13: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 60 (B1-1-ADM-R18-3750-S01-2)
097035: 000061: Nov 11 18:32:19: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1458 (B1-1-ADM-R18-3750-S01-2)
097036: 000062: Nov 11 18:32:24: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1458 (B1-1-ADM-R18-3750-S01-2)
097037: 000063: Nov 11 21:36:02: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1456 (B1-1-ADM-R18-3750-S01-2)
097038: 000064: Nov 11 21:36:07: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1454 (B1-1-ADM-R18-3750-S01-2)
097039: 000065: Nov 11 21:36:13: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1454 (B1-1-ADM-R18-3750-S01-2)
097040: 000066: Nov 12 07:08:14: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1442 (B1-1-ADM-R18-3750-S01-2)
097041: 000067: Nov 12 07:08:19: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1442 (B1-1-ADM-R18-3750-S01-2)
097042: 000068: Nov 12 07:08:24: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1442 (B1-1-ADM-R18-3750-S01-2)
097043: 000069: Nov 12 07:08:34: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1442 (B1-1-ADM-R18-3750-S01-2)
097044: 000070: Nov 12 07:40:35: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 81 (B1-1-ADM-R18-3750-S01-2)
097045: 000071: Nov 12 07:40:40: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 81 (B1-1-ADM-R18-3750-S01-2)
097046: 000072: Nov 12 09:58:20: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1454 (B1-1-ADM-R18-3750-S01-2)
097047: 000073: Nov 12 09:58:23: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1457 (B1-1-ADM-R18-3750-S01-2)
097048: 000074: Nov 12 09:58:29: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1455 (B1-1-ADM-R18-3750-S01-2)
097049: 000075: Nov 12 09:58:34: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1455 (B1-1-ADM-R18-3750-S01-2)
097050: 000076: Nov 12 11:50:50: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1458 (B1-1-ADM-R18-3750-S01-2)
097051: 000077: Nov 12 11:50:55: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 60 (B1-1-ADM-R18-3750-S01-2)
097052: 000078: Nov 12 11:52:09: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1445 (B1-1-ADM-R18-3750-S01-2)
097053: 000079: Nov 12 11:52:14: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1445 (B1-1-ADM-R18-3750-S01-2)
097054: 000080: Nov 12 12:58:52: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1452 (B1-1-ADM-R18-3750-S01-2)
097055: 000081: Nov 12 12:58:57: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 1452 (B1-1-ADM-R18-3750-S01-2)
097056: 000082: Nov 12 13:53:34: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 60 (B1-1-ADM-R18-3750-S01-2)
097057: 000083: Nov 12 13:53:39: %PLATFORM_IPC-3-COMMON: Unknown IPC message type 45529 size 60 (B1-1-ADM-R18-3750-S01-2)
Leo Laohoo
Use 15.0(2)SE4 instead.  15.0(1)SE and higher are full of bugs.
