Error booting Catalyst 2960 series need help
alex.bacalla
i need help somebody deleted boot image.  how can i restore it?
5 Replies 5
sweetfait
If you have a console you can try and boot into ROMmon and xmodem an image to the switch. Be sure to change up the baud rate or you will be there all night. Google the above for a step by step guide..
Good Luck!
Thank you for the quick reply sweetfait. I tried you advice, please see attached images
The error said "No response from the remote system."
glen.grant
First thing is  see if there is a image in flash. Do a dir flash:  and see  if there is any image at all in flash.  If not follow this doc for recovery.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Thank you glen.grant for the reply.  I tried it step by step but the error said " No reply from the remote system".  Please see images above.
I think you missed a step...
You need to select from Hyperterminal window to Send a file to the switch usualy is Tools --> Send File.
Hope this helps
Eugen
