Error Broadcasting
rgdumagpi
Community Member
hows the process of error broadcasting, how it affects the switch?
smalkeric
Level 11
Level 11
A broadcast storm results at the broadcast, receipt, and rebroadcast of packets by each switch. A broadcast storm can cause potentially severe network congestion. Refer URL
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_tech_note09186a00800a7af3.shtml#redundancystorms
tnx a lot,
how about this alert?
Detailed Information :
639: Jan 11 06:52:44: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/2 (1), with TIP-LB-B11F-G14 FastEthernet0/2 (170).
hello ,
This is just an informational log, telling you that there is a mismatch of Native VLANs between this switch and another one TIB-LB-B11F-G14.... You can change the native VLAN in one of these switches and it will stop this error. Its always advicible to have a single native vlan on ur network... refer to this URL:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a008009478e.shtml
Hope this helps.. all the best.. rate replies if found useful..
Raj
is this alert considered as critical...
does it affect any other ports?
how is this alert different from network loop alert?
thanks!
