Error configuring GLC-T on N9K
Cormac Champion
Hi all,
I am trying to configure a 1gb port on a Nexus 9236C.  I have configured the breakout 10gb port and on my Port-Channel, I have set the speed 1000.  However,
PCORE01# sh int eth1/2/1
Ethernet1/2/1 is down (Transceiver speed does not match the speed configured on
the port)
admin state is up, Dedicated Interface
Belongs to Po537
Hardware: 1000/10000 Ethernet, address: 380e.4d74.f25d (bia 380e.4d74.f262)
Description: ** Port-Channel Link to RTR01 g0/2 **
So to confirm, I have the following in the config
interface breakout module 1 port 1-6,33 map 10g-4x
interface Ethernet1/2/1
description ** Port-Channel Link to RTR02 g0/2 **
speed 1000  ( You only get options initially for speed 10000 here but it takes it from the PO config)
channel-group 537
no shutdown
interface port-channel537
speed 1000
NXOS: version 7.0(3)I4(6)
It's wrecking my head !!!
Everything has been resolved and the solution was simply in the fact that I was trying to configure the 1Gb interface on a Breakout of a 40Gb interface.
So the solution is that you simply mount the SFP inside the CVR-QSFP-SFP10G module and set the speed to 1000 - Done !!!
I should point out that I also needed to upgrade the IOS version above the shipped version 7.0(3)I4(6) since that version only supported 1Gb SFP's in a SLIC adapter.
See https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
7 Replies 7
Yachay
Please, could you send the output of the following commands:
sh int e1/2/1 cap
sh int e1/2/1 tran
I moved the interface from Eth1/2 to Eth1/34 so that it would not take up 6 ports
PCORE01# sh int eth1/34/1
Ethernet1/34/1 is down (Transceiver speed does not match the speed configured on
the port)
Belongs to Po537
Hardware: 1000/10000 Ethernet, address: 380e.4d74.f25d (bia 380e.4d74.f2e2)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
auto-duplex, 1000 Mb/s, media type is 40G
Beacon is turned off
Auto-Negotiation is turned on, FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped never
0 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
PCORE01# sh int eth1/34/1 capabilities
Ethernet1/34/1
Model: N9K-C9236C
Type (SFP capable): QSFP-Cazadero
Speed: 1000,10000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated
Port mode: Routed,Switched
QOS scheduling: rx-(8q2t),tx-(7q)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
MDIX: no
TDR capable: no
Link Debounce: yes
Link Debounce Time: yes
FEX Fabric: no
dot1Q-tunnel mode: yes
Pvlan Trunk capable: no
Port Group Members: 133
EEE (efficient-eth): no
PFC capable: yes
Buffer Boost capable: no
Breakout capable: no
MACSEC capable: no
PCORE01# sh int eth1/34/1 transceiver
Ethernet1/34/1
transceiver is present
type is QSFP-Cazadero
name is CISCO-DNI
part number is CAZADERO-R
revision is 03
serial number is DTY213200LV
nominal bitrate is 10000 MBit/sec per channel
cisco id is 13
cisco extended id number is 155
I may have found the answer.  It appears that the GLC-T needs 7.0(3)I5(1) whereas our units came factory installed with the latest recommended stable release of 7.0(3)I4(6)
Despite installing the latest 7.0(3)I7(2) version of NXOS, I'm still no further, so any assistance would be greatly appreciated.
Yachay
It's listed
N9K-C9236C
(QSFP ports with SLIC adapter)
w/ GLC-T
w/ GLC-TE
w/ GLC-SX-MM*
w/ GLC-SX-MMD*
w/ GLC-LH-SM*
w/ GLC-LH-SMD*
7.0(3)I4(1)
