Error DHCP FAILED APIPA IS BEING USING
josueguzman
Community Member
I am getting this error on 4 computers that are in red.
Please help me.
This is the vlsm I used
Martin L
you are not using ROAS, should you?  Perhaps not since you have 2 links Router to switch,  Router LPZ1-01 vlan 108 is in Dot1Q mode and that is a trunk to switch but LPZ1-01 interface vlan 104 is not in dot1Q mode so it should be an access config (not trunk) on L2 Sw 3 switch.   If you want Dot1Q trunk router to switch, use dot1Q on single interface with sub-interfaces on router.  If not, use access config on L2 switch.
So, if not ROAS, replace L2 Sw3 with
interface GigabitEthernet0/1
switchport access vlan 104
switchport mode access
interface GigabitEthernet1/1
switchport mode trunk
interface GigabitEthernet2/1
then re-do ipconfig  /renew on PCs on left side.
THen, you need static routes or routing protocol to exchange routes between routers
Regards, ML
**Please Rate All Helpful Responses **
jonar.isip
Visitor
Can someone help me for this one.
Martin L
Regards, ML
