Error disable recovery interval per cause?
Erik Molenaar
Hi all,
Does anyone know if it is possible to set an error disable recovery interval per cause? Or am i bound to just one interval for all causes?
Seems a bit crude to me to have so many detection categories and only just one over-all recovery index - but maybe is missed something in de the documentation. (IOS version 12.2(55)SE1)
Erik
2 Accepted Solutions
shanemoss
The errdisable recovery interval is a global configuration so you're stuck with a pretty blunt instrument on this one.
Hello Erik,
Actually, if you manage to coerce your Cisco representative to warrant the necessary additions into IOS so that errdisable recoveries can set up in a per-cause fashion, we'll press the button for you
Best regards,
Peter
shanemoss
Thanks.
It's about time to have a good chat with our cisco representative
So now, do i have to press the "correct answer" button that is presented?
Hello Erik,
Best regards,
Peter
