Error disabled, port: Connection timed out
Dragomir
I got a device connected to the 2k, and it has an amber light
sh int ethernet 102/1/2 shows ,
Ethernet102/1/2 is down (Error disabled, port: Connection timed out)
admin state is up,
  Hardware: 100/1000 Ethernet, address: 04da.d2bc.a883 (bia 04da.d2bc.a883)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  auto-duplex, 1000 Mb/s
  Beacon is turned off
  Auto-Negotiation is turned off
  Input flow-control is off, output flow-control is on
  Auto-mdix is turned off
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 5d04h
  52 interface resets
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    411773295 unicast packets  103 multicast packets  181 broadcast packets
    411773579 input packets  488116193109 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    284031519 unicast packets  3775788 multicast packets  14728131 broadcast packets
    302586950 output packets  139657217713 bytes
    527 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
sh run int ethernet 102/1/2
!Command: show running-config interface Ethernet102/1/2
!Time: Sat Mar  9 17:11:01 2013
version 6.1(2)
  switchport access vlan 50
  spanning-tree port type edge
  no shutdown
any idea why? other ports on the same switch as working just fine.
Usually this happens when the interface connect and disconnect several times in a short time frame to a server or another switch.  I have seen this specially happening more with 5ks and 7ks and the only way to bring the interface back up is by doing a sh and no sh.
On the 7ks, when the interface is in error disable, the link light goes amber and also flashes. That is how I know the port is in error disable (when looking at the physical port).
10 Replies 10
Leo Laohoo
Not a Nexus guy, but what do you get when you run the command "sh interface status error"?
there is no sh interface status error
there is show interface status err-disabled
sh int status err-disabled
Port         Name               Status             Reason
Eth102/1/2   --                 err-disabled       Error disabled
Wow.  That's a very helpful (NOT!) output from the Nexus DE.
Enable the ports again and watch carefully the logs on the parent Nexus switch.
What's the client downstream?  Is it another switch?
wow, hat worked. what caused it to err-disable and go offline. why?
Reza Sharifi
If the inteface is in error disable mode
sh and no sh the interface
config t
inter e102/1/2
sh
and then
no sh
thanks that worked. what is causing it to go offline and err-disable?
The output to the command 'sh interface status err" didn't give enough details.  The only place to look is the logs.
i am not familiar with getting the logs. how? the command you gave me nexus does not recognize
yes i noticed that the link light was amber. but it was not flashing.
thanks that was a quick fix.
