error encounted when 'Vlan 4094' configured on Nexus 9K
syjeon
when I configure 'Vlan 4994' on N9K. I can see the following error message.
nexus(config-vlan)# vlan 4094
% Invalid command at '^' marker.
nexus(config-vlan)# name CHshdc_IPT-40.186.0.64/27
nexus(config-vlan)#
nexus(config-vlan)# vlan ?
*** No matching command found in current mode, matching in (config) mode ***
<1-3967> VLAN ID 1-3967 or range(s): 1-5, 10 or 2-5,7-19
access-map Configure a VLAN access map
configuration Vlan feature configuration mode
dot1Q IEEE 802.1Q Virtual LAN
filter Specify access control for packets
Here is system  info.
NAME: "Chassis", DESCR: "Nexus9000 C93128TX Chassis"
PID: N9K-C93128TX
Q. according to sheet, it can supported vlan ID upto 4096. but, actually it isn't. do we have any workaround to configure vlan ID 4096 on N9K?
syjeon
just I noticed Nexus is allocated already vlan range from 3968 - 4047, 4094. so we can't use since it is only internal purposed.
