Error in Cisco 2960 Switch
Dasuntha Dinesh
When I start the switch, I have error !!!WARNING
: The Switch is not usable.
And also,
POST: PortASIC CAM Subsystem Tests: Begin
TCAM (asic:0, bit:55) data bus test failed
Post CAM test failed
unable to create l2trace server process, socket_open() failed
Hope any one can help me to fix it.
Giuseppe Larosa
Hello Dasuntha,
this is an hardware failure of TCAM data bus you need to replace the switch being a fixed configuration switch
if you have a valid service contract you can open an RMA to have the switch replaced.
Hope to help
Giuseppe
Thanks for your reply.
Trying my best to fix it...
Do you think If i try to load the IOS again to the switch & it'll fix the problem...
Hello Dasuntha,
no, it is an hardware problem not a question of IOS image version
Hope to help
Giuseppe
