Error in Switch 3560
majed.balsharaf
   My switch is getting restarted and the error shown is :
System returned to ROM by error - Debug Exception (Could be NULL pointer dereference)
Reza Sharifi
Hi Majed,
It could be a bug in the IOS version you are running.  Here is the bug info:
The recommendation is to upgrade to different version of IOS.  So, try a new version of IOS and see if the problem goes away.
Conditions:
The Catalyst 3560 switch is running Cisco IOS 12.2(20)SE4 (and later)
and PD is detected/classified as "overcurrent class". This problem won't happen
with latest images starting from 12.2(25)SEA
Workaround:
Do NOT connect 802.3af non-standard class PDs or even bad/loopback cables
(as their class can be incorrectly detected) to the switch
Reza Sharifi
Hi Majed,
Conditions:
Workaround:
Hi Reza
The IOS image is
c3560-ipbase-mz.122-25.SEB4.bin
And it was running fine since 6months. Today suddenly it got restarted two times the switch. And its showing me this error.
Majed,
Here is the bug id (CSCsa72400) that is associated with this version.  Go ahead and download a newer version like 12.2(50) or later and load it to your switch.That should resolve your issue.
Good Luck
Reza
Thanks I will update and let you know
