Error logs CRYPTO-6-IKMP_MODE_FAILURE:
ilnaiduccna
Hi All,
I am getting the below logs from one of my router but I couldn't get understand about the logs.
Experts can any body see it and give better suggestions.
Jul 5 12:54:50 GMT: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at (IP_address)
Jul 5 12:56:53 GMT: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at (IP_address)Jul 5 12:57:57 GMT: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at (IP_address)
Jul 5 12:59:06 GMT: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at (IP_address)
Naidu.
Richard Burts
Naidu
Would I be correct in assuming that this router is configured to do IPSec VPN?
In the error messages the reference to IKMP is about ISAKMP which is a component of IPSec. "Processing of Quick mode failed" typically means that some configured parameter in IPSec does not match the parameter configured in the peer device. My suggestion would be to check your IPSec configuration for a mismatched parameter.
Rick
Rick
Hi Rick,
Thanks for your reply, after long time I got interaction with you, feeling so lucky.
Right now I am at remote location while monitoring this device I found this log message
Here jus small information about my prior post.
The router is 3800 and have VPN module so as your assumed there might be IPSec been configured.
3 ATM interfaces
2 Virtual Private Network (VPN) Modules
Naidu :-)
