05-11-2015 06:07 PM - edited 03-07-2019 11:58 PM
A new switch member has just been added. There appears to be a power supply issue as alerted in the switch logs, as noted;
Log:
%PLATFORM_STACKPOWER-4-UNBALANCED_PS: Switch 3's power stack has unbalanced power supplies
When I looked up this issue, research pointed to this bug; CSCtg20513. The bug suggested commands, below;
You can toggle the stack ports (shut/no shut) on the unit that is incorrectly reporting this error.
config t
stack-power switch
standalone
no standalone
However, these commands were ineffective.
Show Version
Version 12.2(55)SE3,
Any other suggestions to can help , is much appreciated!
JoBee
05-12-2015 04:19 AM
That fix is for an earlier version SE2, SE3 is not down as 1 of the effected release that's why it may not be working
12.2(55)SE3 is nearly at deferred state as well i would upgrade to a newer image that's 4 years old now
Have you tried to manually re-seat the power stacks
05-21-2015 01:03 PM
Upgrading later this year, entire campus...thus, for now, issue is apparently fixed? I ran this command "no stack-power switch x" where x = for each switch in the stack, then reload. Afterwards, the error in the logs no longer there.
Thanks for your input.
