Error Msg: Command rejected: Conflict with port based features
GREGORY JACKSON
Level 3
Level 3
I'm getting this error message when tryingto configure a port as a trunk:
The interface I am trying to configure is 6/24 it had been defaulted out and the configuration is blank. When I try and make it a trunk port I get the above error.
My other ports hare configured as below:
interface GigabitEthernet6/23
description Dynamic_Auth_Port
switchport
switchport mode access
switchport voice vlan 281
authentication event fail action authorize vlan 801
authentication event no-response action authorize vlan 801
authentication host-mode multi-domain
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation replace
mab
no snmp trap link-status
dot1x pae authenticator
dot1x timeout quiet-period 10
dot1x timeout tx-period 15
dot1x timeout supp-timeout 31
dot1x max-req 3
storm-control action shutdown
storm-control action trap
spanning-tree portfast edge
end
Anish Palekar
Frequent Visitor
Frequent Visitor
What version of code are you runnning? I am getting this is on 15.1(2)SY
Apparently this is a known bug with Cisco CSCul08799
IPDT: nmsp prevents converting the port from access to trunk
CSCul08799
Description
Symptom:
"nmsp enable" doesn't allow the port to be converted from access to trunk. Even when "nmsp attachment suppress" is configured on the interface, nmsp is not ignored on the interface
Conditions:
"nmsp enable" or "nmsp attachment suppress" under the interface
Workaround:
disable nmsp and default the interface to configure the port as trunk
This required a reboot as well after I executed the commands and rebooted things worked great...
