Error output interface Nexus 3064-PQ NXOS7
arleinalesso
  All interfaces on Nexus 3064-pq have output error.
  Has anyone else had this problem?
# show interface ethernet 1/28
Ethernet1/28 is up
admin state is up, Dedicated Interface
Belongs to Po1000
Hardware: 100/1000/10000 Ethernet, address: a44c.11b7.fc23 (bia a44c.11b7.fc23)
Description:
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
reliability 255/255, txload 94/255, rxload 16/255
Encapsulation ARPA, medium is broadcast
Port mode is trunk
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned off, FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped 5d20h
Last clearing of "show interface" counters 1w0d
4 interface resets
30 seconds input rate 660391312 bits/sec, 277179 packets/sec
30 seconds output rate 3723286584 bits/sec, 442238 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 654.17 Mbps, 273.33 Kpps; output rate 3.74 Gbps, 442.65 Kpps
RX
117934754801 unicast packets 316505 multicast packets 1601080 broadcast packets
117936672386 input packets 35087579994180 bytes
1746085013 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
158244395561 unicast packets 105068926 multicast packets 340622149 broadcast packets
158690086636 output packets 180007802411773 bytes
5628061197 jumbo packets
5984149 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 1022732 output discard
0 Tx pause
# show interface ethernet 1/28 capabilities
Ethernet1/28
Model: N3K-C3064PQ-10GE
Type (SFP capable): 10Gbase-LR
Speed: 100,1000,10000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated
Port mode: Routed,Switched
QOS scheduling: rx-(8q2t),tx-(7q)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
MDIX: no
TDR capable: no
Link Debounce: yes
Link Debounce Time: yes
FEX Fabric: yes
dot1Q-tunnel mode: yes
Pvlan Trunk capable: no
Port Group Members: none
EEE (efficient-eth): no
PFC capable: no
Buffer Boost capable: yes
Breakout capable: no
# show ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2016, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 3.9.0
NXOS: version 7.0(3)I4(4)
BIOS compile time: 01/25/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.4.bin
NXOS compile time: 10/24/2016 15:00:00 [10/24/2016 19:44:16]
Hardware
cisco Nexus3064 Chassis
Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3903432 kB of memory.
Processor Board ID FOC16251623
Device name: SWELETSPO001
bootflash: 1635720 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 160 day(s), 16 hour(s), 16 minute(s), 4 second(s)
Last reset at 68263 usecs after Tue Dec 27 01:57:22 2016
Reason: Disruptive upgrade
System version: 6.0(2)U6(8)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
0 Replies 0
