ERROR: 'switchport access vlan' is not supported on L3 interface
jjevans
I am trying to add ports to vlan 1000
Vlan 1000
Name vlan
interface Vlan1000
  no shutdown
  no ip redirects
  ip address 10.20.55.1/26
  no ipv6 redirects
  ip router eigrp 100
  ip passive-interface eigrp 100
interface Ethernet1/1-48
switchport mode access
  switchport access vlan 1000
  spanning-tree port type edge
Try to add vlan 1000 to port 1-48 but I get ERROR: eth1/1: 'switchport access vlan' is not supported on L3 interface
I do a show run and none of the ports are assigned to vlan 1000??? Not 1/1 -1/48 What am I doing wrong? TIA
switch# show run
interface Ethernet1/2
interface Ethernet1/3
NXOS image file is: bootflash:///nxos.9.3.2.bin
Jon Marshall
Looks like interfaces are L3 by default so to change just type "switchport" in interface configuration mode then run your command again.
Jon
Jon Marshall
Jon
incorrect you have it backwards
Have what backwards, do you mean they are L2 by default ?
If so then I guess eth1/1 must have been changed at some point.
Jon
Doh! Thank you John
