Error with TCAM
megalloid
Community Member
I have any problem with Cisco ASR1001-X.
Problem comes when device start's and after up interfaces. If create 3 subinterfaces with 8094 QinQ vlan's - i have no problems.
After I create 4th subinterface - I have problems messages, IPoE doesnt works.
And what is port 1 means in log?
Logging:
*May 11 08:16:40.136: %SMART_LIC-6-AGENT_READY: Smart Agent for
Licensing is initialized
*May 11 08:16:41.154: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL:
Module name = asr1001x Next reboot level = adventerprise and License =
adventerprise
*May 11 08:16:43.180: %IOSXE_THROUGHPUT-6-LEVEL: Throughput level has
been set to 20000000 kbps
*May 11 08:16:49.936: pak_debug_init: Successfully initialized pak debug
trace buffer
*May 11 08:16:54.100: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled
for type vlan
*May 11 08:16:57.313: %VOICE_HA-7-STATUS: CUBE HA-supported platform
detected.
*May 11 08:16:58.285: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*May 11 08:16:58.285: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*May 11 08:16:58.285: %LINEPROTO-5-UPDOWN: Line protocol on Interface
VoIP-Null0, changed state to up
LI-Null0, changed state to up
*May 11 08:16:58.285: %LINK-3-UPDOWN: Interface GigabitEthernet0,
changed state to down
*May 11 08:16:58.288: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*May 11 08:17:00.318: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management
vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*May 11 08:17:00.433: %LINEPROTO-5-UPDOWN: Line protocol on Interface
GigabitEthernet0, changed state to down
*May 11 08:16:45.563: %CMLIB-6-THROUGHPUT_VALUE: F0: cmand: Throughput
license found, throughput set to 20000000 kbps
*May 11 08:16:46.180: %CPPHA-7-START: F0: cpp_ha:  CPP 0 preparing ucode
*May 11 08:16:46.357: %CPPHA-7-START: F0: cpp_ha:  CPP 0 startup init
*May 11 08:16:50.003: %IOSXE-4-PLATFORM: R0/0: kernel: OCTEON[0]:
Received active indication from core
octeon_core_drv_init: ctx_chunks = 14000
octeon_core_drv_init: boot_log_ptr=12d580
octeon_core_drv_init: Build = N2-Like IPSec Version:
2.3.0-101-03-0402-91831-ilkx-CR  N2-Like SSL Version: 2.3.0-101-03-0402-9
*May 11 08:16:50.003: %IOSXE-4-PLATFORM: R0/0: kernel: OCTEON[0] is
running BASE application (core clock: 1100000000 Hz)
*May 11 08:16:50.320: %CPPHA-7-START: F0: cpp_ha:  CPP 0 running init
*May 11 08:16:50.661: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and
initialization complete
*May 11 08:16:50.774: %IOSXE-6-PLATFORM: SIP0: cpp_cp: Process
CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*May 11 08:16:51.390: %IOSXE-4-PLATFORM: R0/0: kernel: OCTEON[0] Poll
Function (Module Starter arg: 0x0) completed (status: Finished)
*May 11 08:17:00.951: %CMCC-3-PLIM_STATUS: SIP0: cmcc:  A PLIM driver
informational error Ysn-Mgp1 - fifoErr6, block 26 count 1
000031: *May 11 08:17:02: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging:
level debugging, xml disabled, filtering disabled, size (5000000)
000032: *May 11 08:17:02: %SYS-5-LOG_CONFIG_CHANGE: Monitor logging disabled
000033: *May 11 13:17:02: %SYS-6-CLOCKUPDATE: System clock has been
updated from 08:17:02 UTC Wed May 11 2016 to 13:17:02 YEKT Wed May 11
2016, configured from console by console.
000034: *May 11 13:17:02: %LINEPROTO-5-UPDOWN: Line protocol on
Interface Loopback0, changed state to up
000035: *May 11 13:17:03: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host
91.205.237.49 port 0 CLI Request Triggered
000036: *May 11 13:17:03: %SYS-5-CONFIG_I: Configured from memory by console
000037: *May 11 13:17:03: %IOSXE_OIR-6-REMSPA: SPA removed from subslot
0/0, interfaces disabled
000038: *May 11 13:17:03: %SPA_OIR-6-OFFLINECARD: SPA
(BUILT-IN-2T+6X1GE) offline in subslot 0/0
000039: *May 11 13:17:03: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in
slot F0
000040: *May 11 13:17:03: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in
slot F0
000041: *May 11 13:17:03: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
000042: *May 11 13:17:03: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in
slot 0
000043: *May 11 13:17:03: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
000044: *May 11 13:17:03: %SYS-5-RESTART: System restarted --
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M),
Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 30-Jan-15 14:23 by mcpre
000045: *May 11 13:17:03: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
000046: *May 11 13:17:03: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
000047: *May 11 13:17:06: %LINEPROTO-5-UPDOWN: Line protocol on
Interface Virtual-Access2, changed state to up
000048: *May 11 13:17:06: %LINK-3-UPDOWN: Interface Virtual-Access2,
changed state to up
000049: *May 11 13:17:06: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host
91.205.237.49 port 514 started - CLI initiated
000050: *May 11 13:17:08: %SNMP-5-COLDSTART: SNMP agent on host 205 is
undergoing a cold start
000051: *May 11 13:17:10: %LINK-3-UPDOWN: Interface GigabitEthernet0,
changed state to up
000052: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to insert into VLAN TCAM
000053: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 785 on port 1
000054: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000055: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 786 on port 1
000056: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000057: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 787 on port 1
000058: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000059: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 788 on port 1
000060: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000061: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 789 on port 1
000062: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000063: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 790 on port 1
000064: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000065: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 791 on port 1
000066: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000067: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 792 on port 1
000068: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000069: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 793 on port 1
000070: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000071: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 794 on port 1
000072: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000073: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 795 on port 1
000074: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000075: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 796 on port 1
000076: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000077: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 797 on port 1
000078: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000079: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 798 on port 1
000080: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000081: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 799 on port 1
000082: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000083: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 800 on port 1
000084: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000085: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 801 on port 1
000086: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000087: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 802 on port 1
000088: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000089: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 803 on port 1
000090: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000091: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outerN TCAM
000092: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 891 on port 1
000093: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000094: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 892 on port 1
000095: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000096: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 893 on port 1
000097: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000098: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 894 on port 1
000099: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000100: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 895 on port 1
000101: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000102: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 512 on port 1
000103: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000104: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 513 on port 1
000105: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000106: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 514 on port 1
000107: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000108: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 515 on port 1
000109: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000110: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 516 on port 1
000111: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000112: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 517 on port 1
000113: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000114: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 518 on port 1
000115: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000116: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 519 on port 1
000117: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000118: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 520 on port 1
000119: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000120: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 521 on port 1
000121: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000122: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 522 on port 1
000123: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000124: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 523 on port 1
000125: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000126: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 524 on port 1
000127: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000128: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 525 on port 1
000129: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000130: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 526 on port 1
000131: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to insert int 3904 inner vlan 539 on port 1
000132: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000133: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 540 on port 1
000134: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000135: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 541 on port 1
000136: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000137: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 542 on port 1
000138: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
000139: *May 11 13:17:10: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM
Failed to set outer vlan 3904 inner vlan 543 on port 1
Mark Malone
That looks like a bug software defect as there is another very similar know one CSCuu50414
%IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM Failed to insert into DA TCAM
You could check the release notes for the IOS-XE image online see if it has vlan TCAM error, if its known or take a chance and upgrade to a newer image , if your on the latest image you may have to go through TAC
I dont have access to this information on CSCuu50414. Can you give any information for troubleshooting of this bug?(
The bug is locked from public view only TAC can release the details of it
Kanes Ramasamy
Level 3
Level 3
Were you able to identify the fault/reason the errors message occurred?
I am currently on version 15.5(3) S1a and the error messages received are as following:
*Dec 11 22:06:53.033: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM Failed to set outer vlan 52 inner vlan 3990 on port 3
*Dec 11 22:06:53.250: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM Failed to insert into VLAN TCAM
*Dec 11 22:06:53.250: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM Failed to set outer vlan 52 inner vlan 3991 on port 3
*Dec 11 22:06:53.562: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: LPM Failed to insert into VLAN TCAM
Hope you can share the outcome of the error.
Thanks and Regards,
kanes.R
