ERSPAN and SPAN to same destination
montyr14cisco
Hello community,
I have a requirement to set up the monitoring on two separate Nexus switches. One already has a local SPAN set up and working and I wish to set up an ERSPAN from the second Nexus switch and send the traffic to the same destination. There does not appear to be an issue getting ERSPAN to work but I was not able to find anywhere documented how to send the local and remote traffic to the same destination port, most documents mention one or the other and that only one session per destination can be configured.
I will greatly appreciate any advice.
exnerd
Hello, have you solved this? I have exactly same requirement from my customer.
Thanks, David
