etharchannel in two different switch
bkshrestha
i want to load balancing two different cisco switch. how it is possible.
two switch meaing:
sw1 is connected from fiber in l3 switch.
sw2
sw3
sw4 is connected from cat6 in l3 switch
so i would like to eharchannel in sw1 to l3, s1 to sw2, sw2 to sw3, s3 to sw4 and sw4 to l2 switch from cat6.please suggest.
Tom Watts
What switch model #?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
l2 switch is c2960
l3 is c3750
Bikash, so long as the config matches there should be no problems. You may make the channel-group, assign to the group number you want, I'd recommend to use mode "on" instead of active or passive. This will make a static LAG.
The one thing to take notice of, when you make the LAG between switches, you may make the ports go in to err disable. Just shut/no shut the ports once the config is complete to bring the lag up accordingly.
so something like
config t
int range xxx
channel-group 1 mode on
-Tom
