PFC enabled? show queuing interface - Per-priority-pause status
nermushermus
Community Member
On the Nexus 5596 I have the following configured for the port (no lldp transmit and receive) due to iSCSI TLV not supported by Nexus (at the moment):
interface Ethernet1/21
  no lldp transmit
  no lldp receive
  switchport access vlan xx
  flowcontrol receive on
  flowcontrol send on
  channel-group x
However under show queuing interface I see Tx active for Per-priority-pause status:
Ethernet1/21 queuing information:
  TX Queuing
    qos-group  sched-type  oper-bandwidth
        0       WRR              5
        3       WRR             95
  RX Queuing
    qos-group 0
    q-size: 350080, HW MTU: 1500 (1500 configured)
    drop-type: drop, xon: 0, xoff: 350080
    Statistics:
        Pkts received over the port             : 0
        Ucast pkts sent to the cross-bar        : 0
        Mcast pkts sent to the cross-bar        : 0
        Ucast pkts received from the cross-bar  : 0
        Pkts sent to the port                   : 0
        Pkts discarded on ingress               : 0
        Per-priority-pause status               : Rx (Inactive), Tx (Inactive)
    qos-group 3
    q-size: 90240, HW MTU: 9216 (9216 configured)
    drop-type: no-drop, xon: 17280, xoff: 37120
    Statistics:
        Pkts received over the port             : 328665922
        Ucast pkts sent to the cross-bar        : 328665646
        Mcast pkts sent to the cross-bar        : 231
        Ucast pkts received from the cross-bar  : 356032494
        Pkts sent to the port                   : 356032384
        Per-priority-pause status               : Rx (Inactive), Tx (Active)
Am I missing something?
Thank you
ansverma
can you share show lldp interface
Also try to bounce the lldp feature.
Anshul
Thanks Anshul,
Does the "Per-priority-pause status: Rx (Inactive), Tx (Active)" mean PFC is Tx enabled?  This is an iSCSI setup and as I understand it, Nexus does not support the iSCSI TLV for DCB at this time.  We would certainly want to disable this PFC if it is enabled, but if this will not cause issues then we can overlook it.
I only have the show tech-support currently, but I have requested the output of the command you requested.  Would the following suffice?  It shows Tx and Rx disabled, however the interface is receiving DCBX frames.  I will post the output of the requested as soon as I receive it.
`show lldp dcbx interface Ethernet1/21 `
Local DCBXP Control information:
Operation version: 00  Max version: 00  Seq no: 1  Ack no: 0
Type/
Subtype    Version    En/Will/Adv Config
003/000     000        Y/N/Y      1008
004/000     000        Y/N/Y      8906001b21 08
002/000     000        Y/N/Y      0000100064 00000000 00000002
`show system internal dcbx info interface Ethernet1/21 `
Interface info for if_index: 0x1a014000(Eth1/21)
tx_enabled: FALSE
rx_enabled: FALSE
dcbx_enabled: FALSE
DCX Protocol: CEE
DCX CEE NIV extension: disabled
Port MAC address:  00:05:73:e5:42:9c
DCX Control FSM Variables: seq_no: 0x1, ack_no: 0x0,my_ack_no: 0x0, peer_seq_no: 0x0 oper_version: 0x0,  max_version: 0x0 fast_retries 0x0
Lock Status: UNLOCKED
PORT STATE: UP
LLDP Neighbors
No DCX tlvs from the remote peer
6 Features on this intf for Protocol DCX CIN(0)
Feature type PFC (3)
feature type 3(DCX CIN-PFC)sub_type 0
Feature State Variables: oper_version 0 error 0 local error 0 oper_mode 0
     feature_seq_no 0 remote_feature_tlv_present 0 remote_tlv_aged_out 0
     remote_tlv_not_present_notification_sent 0
Feature Register Params: max_version 0, enable 1, willing 0 advertise 1
     disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0x179
Desired config cfg length: 1 data bytes:10
Operating config cfg length: 0 data bytes:
Peer config cfg length: 0 data bytes:
Feature type LLS (6)sub_type FCoE Logical Link Status (0)
feature type 6(DCX CIN-LLS)sub_type 0
     disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0x1d9
Desired config cfg length: 1 data bytes:00
Feature type App (5)sub_type FCoE iSCSI (0)
feature type 5(DCX CIN-App)sub_type 0
     feature_seq_no 0 remote_feature_tlv_present 0 remote_tlv_aged_out 1
Desired config cfg length: 1 data bytes:08
Feature type PriMtu (8)
feature type 8(DCX CIN-PriMtu)sub_type 0
Desired config cfg length: 16 data bytes:05    dc    05    dc    05    dc    05    dc    24    00    05    dc    05    dc    05    dc
Feature type PriGrp (2)
feature type 2(DCX CIN-PriGrp)sub_type 0
Desired config cfg length: 24 data bytes:64    00    00    00    00    00    00    00    00    0f    00    0f    00    0e    00    0e    20    64    00    0e    00    0e    00    0e
Feature type LLS (6)sub_type LAN Logical Link Status (1)
feature type 6(DCX CIN-LLS)sub_type 1
     disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0xaf
Desired config cfg length: 1 data bytes:80
3 Features on this intf for Protocol DCX CEE(1)
feature type 3(DCX CEE-PFC)sub_type 0
Desired config cfg length: 2 data bytes:10    08
Feature type App (4)sub_type FCoE iSCSI (0)
feature type 4(DCX CEE-App)sub_type 0
     remote_tlv_not_present_notification_sent 1
Desired config cfg length: 6 data bytes:89    06    00    1b    21    08
feature type 2(DCX CEE-PriGrp)sub_type 0
Desired config cfg length: 13 data bytes:00    00    10    00    64    00    00    00    00    00    00    00    02
Features on this intf for LLDP
lldp feature type 2(PriMtu)sub_type 0
lldp feature register params max_version 0, enable 1, willing 0 advertise 1, disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0x179
lldp feature type 1(LLS)sub_type 1
lldp feature register params max_version 0, enable 1, willing 0 advertise 1, disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0xaf
Desired config cfg length: 1 data bytes:01
Traffic Counters
DCBX pkt stats:
    Total frames out: 61083
    Total Entries aged: 17
    Total frames in: 60613
    DCBX frames in: 60318
    Total frames received in error: 0
    Total frames discarded: 0
    Total TLVs unrecognized: 0
Here is the output of the requested command:
Switch1-5596# show lldp interface ether1/21
Interface Information:
  Enable (tx/rx/dcbx): N/N/N    Port Mac address: 00:05:73:e5:42:9c
