Ether channel not working
I was configured ether channel between two cisco 2960s series switches.It is working properly.i was replaced two cables in etherchannel.Now one link working remining link is down(both cables are working cables only).please find below ether channel details
CORESWITCH#show etherchannel detail
                Channel-group listing:
Group: 1
Group state = L2
Ports: 3   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:   PAgP
Minimum Links: 0
                Ports in the group:
Port: Gi0/42
Port state    = Up Mstr In-Bndl
Channel group = 1           Mode = Desirable-Sl    Gcchange = 0
Port-channel  = Po1         GC   = 0x00010001      Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   PAgP
Flags:  S - Device is sending Slow hello.  C - Device is in Consistent state.
        A - Device is in Auto mode.        P - Device learns on physical port.
        d - PAgP is down.
Timers: H - Hello timer is running.        Q - Quit timer is running.
        S - Switching timer is running.    I - Interface timer is running.
Local information:
                                Hello    Partner  PAgP     Learning  Group
Port      Flags State   Timers  Interval Count   Priority   Method  Ifindex
Gi0/42    SC    U6/S7   H       30s      1        128        Any      5001
Partner's information:
          Partner              Partner          Partner         Partner Group
Port      Name                 Device ID        Port       Age  Flags   Cap.
Gi0/42    NEWBUILDINGSWITCH    08d0.9fbb.8e80   Gi1/0/45    15s SAC     10001
Age of the port in the current state: 0d:00h:52m:18s
Port: Gi0/43
Port state    = Down Not-in-Bndl
Port-channel  = null        GC   = 0x00000000      Pseudo port-channel = Po1
        d - PAgP is down.
Local information:
Gi0/43    d     U1/S1           1s       0        128        Any      0
Age of the port in the current state: 0d:00h:42m:52s
Port: Gi0/44
        d - PAgP is down.
Local information:
Gi0/44    SC    U6/S7   H       30s      1        128        Any      5001
Gi0/44    NEWBUILDINGSWITCH    08d0.9fbb.8e80   Gi1/0/43     2s SAC     10001
Age of the port in the current state: 0d:00h:26m:33s
                Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 6d:04h:01m:18s
Logical slot/port   = 2/1          Number of ports = 2
GC                  = 0x00010001      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   PAgP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi0/42   Desirable-Sl       0
  0     00     Gi0/44   Desirable-Sl       0
Time since last port bundled:    0d:00h:26m:40s    Gi0/44
Time since last port Un-bundled: 0d:00h:42m:37s    Gi0/44
NEWBUILDINGSWITCH#show etherchannel detail
Group: 1
Group state = L2
Protocol:   PAgP
Minimum Links: 0
                Ports in the group:
Port: Gi1/0/43
Channel group = 1           Mode = Automatic-Sl    Gcchange = 0
        d - PAgP is down.
Local information:
Gi1/0/43  SAC   U6/S7   HQ      30s      1        128        Any      5001
Gi1/0/43  CORESWITCH           d057.4c03.3700   Gi0/44      16s SC      10001
Age of the port in the current state: 0d:00h:28m:24s
Port: Gi1/0/44
        d - PAgP is down.
Local information:
Gi1/0/44  dA    U1/S1           1s       0        128        Any      0
Age of the port in the current state: 0d:00h:31m:58s
Port: Gi1/0/45
        d - PAgP is down.
Local information:
Gi1/0/45  SAC   U6/S7   HQ      30s      1        128        Any      5001
Gi1/0/45  CORESWITCH           d057.4c03.3700   Gi0/42      12s SC      10001
Age of the port in the current state: 0d:00h:54m:13s
Port-channel: Po1
Age of the Port-channel   = 6d:03h:51m:55s
Logical slot/port   = 5/1          Number of ports = 2
Protocol            =   PAgP
  0     00     Gi1/0/43 Automatic-Sl       0
  0     00     Gi1/0/45 Automatic-Sl       0
Time since last port bundled:    0d:00h:28m:27s    Gi1/0/43
Time since last port Un-bundled: 0d:00h:44m:24s    Gi1/0/44
9 Replies 9
cadet alain
Can you post sh run interface x/x on both switches where x/x is the id of the interface which is down in the port-channel.
Regards.
Alain
on core switch
interface GigabitEthernet0/42
description ***NEW BUILDING ETHERCHANNEL***
channel-protocol pagp
channel-group 1 mode desirable
interface GigabitEthernet0/43
interface GigabitEthernet0/44
Another switch
interface GigabitEthernet1/0/43
channel-group 1 mode auto
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
post sh interface outputs on both switches.
Regards.
Alain
CORESWITCH#show int Gi0/42
GigabitEthernet0/42 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is d057.4c03.372a (bia d057.4c03.372a)
  Description: ***NEW BUILDING ETHERCHANNEL***
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 213/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:12, output 00:00:06, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 30751
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 792000 bits/sec, 377 packets/sec
  5 minute output rate 83532000 bits/sec, 7156 packets/sec
     231271889 packets input, 109221409016 bytes, 0 no buffer
     Received 1089145 broadcasts (487310 multicasts)
     0 watchdog, 487310 multicast, 0 pause input
     115954441 packets output, 120219113665 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
CORESWITCH#show int Gi0/43
GigabitEthernet0/43 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is d057.4c03.372b (bia d057.4c03.372b)
     reliability 251/255, txload 1/255, rxload 1/255
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  Last input 01:15:10, output 01:15:07, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 52242
     82876817 packets input, 22469717382 bytes, 0 no buffer
     Received 548527 broadcasts (341582 multicasts)
     0 runts, 1 giants, 0 throttles
     11948 input errors, 1460 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 341582 multicast, 0 pause input
     288162823 packets output, 281889715047 bytes, 0 underruns
     0 output errors, 0 collisions, 11 interface resets
CORESWITCH#show int Gi0/44
GigabitEthernet0/44 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is d057.4c03.372c (bia d057.4c03.372c)
     reliability 255/255, txload 13/255, rxload 22/255
  Last input 00:00:04, output 00:00:04, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 54904
  5 minute input rate 8637000 bits/sec, 4671 packets/sec
  5 minute output rate 5335000 bits/sec, 1126 packets/sec
     124351618 packets input, 65103069792 bytes, 0 no buffer
     Received 1187100 broadcasts (684254 multicasts)
     0 watchdog, 684254 multicast, 0 pause input
     168776519 packets output, 70512945800 bytes, 0 underruns
NEWBUILDINGSWITCH#show int Gi1/0/43
GigabitEthernet1/0/43 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 08d0.9fbb.8eab (bia 08d0.9fbb.8eab)
     reliability 255/255, txload 17/255, rxload 11/255
  Last input 00:00:06, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 12406
  5 minute input rate 4546000 bits/sec, 976 packets/sec
  5 minute output rate 7049000 bits/sec, 4412 packets/sec
     169723008 packets input, 71567664383 bytes, 0 no buffer
     Received 7883327 broadcasts (3342459 multicasts)
     2360 input errors, 703 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 3342459 multicast, 0 pause input
     122746576 packets output, 64942164220 bytes, 0 underruns
NEWBUILDINGSWITCH#show int Gi1/0/44
GigabitEthernet1/0/44 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 08d0.9fbb.8eac (bia 08d0.9fbb.8eac)
  Last input 01:16:38, output 01:16:37, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 5638
     287251008 packets input, 280850396126 bytes, 0 no buffer
     Received 6799136 broadcasts (3125060 multicasts)
     3 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 3125060 multicast, 0 pause input
     84844118 packets output, 22662324029 bytes, 0 underruns
NEWBUILDINGSWITCH#show int Gi1/0/45
GigabitEthernet1/0/45 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 08d0.9fbb.8ead (bia 08d0.9fbb.8ead)
     reliability 255/255, txload 1/255, rxload 205/255
  Last input 00:00:03, output 00:00:07, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 21608
  5 minute input rate 80714000 bits/sec, 6888 packets/sec
  5 minute output rate 630000 bits/sec, 322 packets/sec
     116930544 packets input, 121534852805 bytes, 0 no buffer
     Received 5823000 broadcasts (1767161 multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1767161 multicast, 0 pause input
     231520917 packets output, 109271535472 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
but cable is connected on interface (Cable is working )
What do you mean by that ?
Regards.
Alain
GigabitEthernet1/0/44 is down, line protocol is down (notconnect),,network cable is connected on interface,but it showing down.
Have you verified your cable? What if you take this cable and link different interfaces, is it still down/down ?
I suppose it was working before with same cable and same interfaces ?
Regards.
Alain
i was reverted the cables .still that port is down
No issues resolved .Issue with physical cable length.
