LAN port speed issue
                   I am facing port speed issue on WS-C2960G-48TC-L series switch.This switch gig0/X ports connected to onother switches (Cisco and HP both switches are also gigbit ports and directly connected ).but interface is giving only 100mb/s output.
ios on WS-C2960G-48TC-L is 12.2(44)SE6
As I can see For sh cable tdr int gi1/0/44
Cable length is between almost 90 metres.  The test can "see" Pair A and B are normal.  Pair c is used for POE and its seems to normal as well but Pair "D" supports GigabitEthernet which is open and not good so it suppose to be normal.
sh cable tdr int gi1/0/45
this interface seems to normal
sh cable tdr int gi1/0/43
for this interface Pair C is open so it means POE is not working but Pair D is normal and support Gig interface
Gig interface, I will never (ever) take a cable unless all four pairs are tested Normal.
So please try to change the cable for int gi1/0/44, which shows Gig interface OPEN.
thanks
15 Replies 15
srikanth ath
Level 4
Level 4
Hello ,
If the the connected switches ports are gig's, please configure the both ports to duplex and speed to 1000.
example:
sw# int gig 1/0/1
sw# speed 1000  / or you can set  speed as auto
sw# duplex full / or auto
sw#end
Please rate the helpful posts, let us know if you have any issues.
thanks,
srikanth
Thanks srikanth,
i was configured speed 1000 and duplex auto .port down once i configurd .
at present speed auto and duplex full on both sides.
Kindly clear all the commands of the interface and  set speed and duplex to auto at both the  sides and issue shut and no shut.
srikanth
                   Hi Srikanth,
Please find the attached running config files.
Hi chakradhar,
Try to change the bandwidth to 1 GB and then try
thanks
Hi Amrinder singh,
I was done this also
sw# int gig 1/0/1
sw# speed 1000
sw# duplex full
sw#end
please try these commands on that interface and post the config
1.  Command:  test cable tdr interface Gig0/x
2.  Wait for approximately 5 to 7 seconds;
3.  Command:  sh cable tdr interface Gig0/x and
4.  Please post the output
looks like your network cable is faulty
thanks
Hi ,
If i will run above comands,port is up or down because it is in production network and around 300 users are connected .Please conform my network will effect if i will run above comands
hello,
its safe to run. its not going to effect any int status.
i have done it so many times.
thanks
Hi Amrinder,
please fine any issue on below output
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/43  auto  Pair A     93   +/- 0  meters N/A         Normal
                Pair B     91   +/- 0  meters N/A         Normal
                Pair C     87   +/- 1  meters N/A         Open
                Pair D     93   +/- 0  meters N/A         Normal
singhaam007
Level 3
Level 3
Hi chakradhar,
could you please post config of both switches and lets see if i can help.
thanks
singhaam007
Level 3
Level 3
hi Mate
ur cable is faulty. all the pair suppose to be normal for Gig interface.
check this out.please try to replace it and try again.
Result
Explaination
Normal
Ideal result you want.
  • If testing FastEthernet, you want Pair A and B as “Normal”.
  • If testing GigabitEthernet, you want ALL as “Normal”.
Open
Open circuit. This means that one (or more) pair has “no pin contact”.
Short
Short circuit.
Impedance Mismatched
Bad cable.
please rate if this helps
thanks
Hi Thanks for your update, and 3 cables are connected between switches find the belw output
NEWBUILDINGSWITCH#test cable-diagnostics tdr int gi1/0/44
TDR test started on interface Gi1/0/44
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
NEWBUILDINGSWITCH#sh cable tdr int gi1/0/44
TDR test last run on: September 24 10:45:43
Gi1/0/44  auto  Pair A     96   +/- 0  meters N/A         Normal
                Pair B     93   +/- 0  meters N/A         Normal
                Pair C     92   +/- 0  meters N/A         Normal
                Pair D     92   +/- 1  meters N/A         Open
NEWBUILDINGSWITCH#test cable-diagnostics tdr int gi1/0/45
TDR test started on interface Gi1/0/45
NEWBUILDINGSWITCH#sh cable tdr int gi1/0/45
TDR test last run on: September 24 10:46:19
Gi1/0/45  auto  Pair A     96   +/- 0  meters N/A         Normal
                Pair B     92   +/- 0  meters N/A         Normal
                Pair D     95   +/- 0  meters N/A         Normal
NEWBUILDINGSWITCH#test cable-diagnostics tdr int gi1/0/43
TDR test started on interface Gi1/0/43
NEWBUILDINGSWITCH#sh cable tdr int gi1/0/43
TDR test last run on: September 24 10:46:57
NEWBUILDINGSWITCH#
as per above clarification in this output at lease one cable working properly, but 3 cables or giving same output.Please check the above cable test details
thanks
