I'm supporting a system administrator with a Windows server with two 100 Mbps interface connections to a 3750 access switch, IOS is basic 12.55SE1, which is part of a stack of 3 total switches . The server's IP is reachable by Layer 3 connections i.e. devices not on the server's VLAN subnet, but at layer 2, connected to the same switch in the same VLAN, devices cannot reach the server. I have tried removing the ether cahnnel configuration but am unable to re establish a layer 3 connection on either of the two ports. Would appreciate any ideas on jow to resolve this. Thanks
