Etherchanel...
Debudas123
Level 5
Level 5
                   How many etherchanel group i can configure in cisco WS-C2960S-24TS-S and WS-C3750X-12S-S ?
Reagrds
Debabrata
hI Debdas,
so that i can use Channel-Group id 7, 9, 10 like this in 2960, there is no limitation in ID no.,but maximum is 6.
Yes you can use any number for a port channel.
yes you can create maximum 6  port-channel on 2960 switches and 48 port channel on 3750 switch.
If you are satisfied then please mark this question as answered!
Please rate it, if it helps.
Sandeep Choudhary
HI Debudas,
Its a hardware limitaion.You will not get more etherchannels even if you upgrade.
Please rate if it helps.
Okay ... i understad.....
Thanks ... so that i can use Channel-Group id 7, 9, 10 like this in 2960, there is no limitation in ID no., but maximum is 6.
Debabrata
hI Debdas,
