Etherchannel Advice
oliver.webb1
Community Member
I've got one stack of two Cisco Catalyst 2960S switches and one stack of three Cisco 2960S switches. Between these I have 4 Cat5 ethernet cables.
What would be the best way of configuring the links between the two stacks?
I'm thinking of a Cross-Stack EtherChannel, but is it better to have one EtherChannel with 4 ports, or 2 EtherChannels with 2 ports each?
On the Cisco site it states that a GigaBit EtherChannel can provide 8 Gb/s. Does this vary depending on how many ports are assigned to the channel?
Many thanks,
Ollie
Mark Malone
hi
PAGP supports 8 links but LACP 16 links all gig  ,I would cross connect them  between the stacks for extra resiliency
Joseph W. Doherty
I would recommend one of 4 ports.  Why?  One logical link rather than two.
Two ports on each stack member for the stack of two.  For the stack of three, either two ports on one stack member and one each on the other stack members, or two ports on two of the stack members.
As Mark mentions, some later devices support more.  Originally, though, EtherChannel was limited to 8 links.
Yes, maximum bandwidth depends on links assigned.
There are other "gotchas".  Such as:  any one flow will only use one link.  EtherChannel hashes flows across links regardless of current link usage.  Flow distribution depends on the nature of your frames/packets and the hash algorithm being used.  EtherChannel usually hashes best across a power of two number of links.  If you need more than four EtherChannel links, you might investigate whether you would be better served by moving to the next jump in Ethernet bandwidth (if available).
Thanks Mark and Joseph, that's helped a lot.
Ollie
