Etherchannel and Trunk
mstillante
Good evening,
I'm trying to make and etherchannel working also as trunking between a router and a switch L3 but not successiding .
does anybody have any clue how this can be possible?
any documentation where i can find it out ?
what is the configuration i shoud follow ?
thks very much
/michelangelo
hi i solved by myself ... thks anyway
5 Replies 5
Reza Sharifi
What type of router and switch are you using? What is the interface type? Are they all 1Gig, 10Gig, etc...
Can you provide more info about your setup?
balaji.bandi
Please provide below information :
1. what is the device models
2. what IOS running on it
3. what is the interface and prefer to show all the config.
router and a switch L3 but not successiding  - explain more
or check this what you looking :
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
BB
ps: the link you provided me was not helpful for my topic
balaji.bandi
thank you for the feedback - your orginal post  do not consists enough information, and we do not know what exactly you are doing what is not working.
I only given reference, this does not mean it will solve the issue.
BB
