Etherchannel and VRRP
arifmrafi9
Hi All,
 I am a new guy to the networking domain have a doubt in etherchanneling the ports and VRRP. Please find the attached diagram for your reference.
Is it possible to etherchannel at one end(DISTRIBUTION SWITCH) and connect one link to core_switch1 and other link to core_switch2. These core switches are connected through VRRP.
Please help.
Thanks In Advance,
AMR
2 Accepted Solutions
Mark Malone
Hi for that to work your core switches would need to be VSS or stacked together , port-channel links must terminate on same switch unless its one of the previous mentioned
It is not possible unless your core switch is a VSS set up.
Madhu
Mark Malone
Madhu
arifmrafi9
 Thank you Mark Malone and Madhu for your information.
Your suggestions were very helpful.
Thank you..
