04-17-2009 02:52 AM - edited 03-06-2019 05:14 AM
hi,
i am trying to configure etherchannel between cisco 6509 and nortel 8600 switch. but soon after configuring the port channel interfaces are going in error disable state. could anyone send the configuration for creating L2 etherchannel between cisco and nortel switches.
Thanks & Regards
Rajeev
Solved! Go to Solution.
04-19-2009 03:09 PM
hello rajeev,
Nortel uses MLT for etherchannel configs.
have a look at page 329 of the attached doc.
04-19-2009 03:09 PM
06-30-2009 10:00 PM
Thanks...
Rajeev
07-19-2009 07:05 AM
Description: Multicast problem:
Topology :Remote site->MPLS cloud->switch1 3750->ASA 5510-> LAN switch 3560E
Switch1 inside interface(int vlan) which is connected to ASA is configured with IP PIM passive.
Q: Will my multicast work on LAN and able to receive multicast traffic from remote site?
07-20-2009 04:06 AM
you'll need multicast VPN inside the MPLS cloud. Ask your ISP if they have it - they should.
11-04-2009 09:30 PM
Thanks for your comment...
yes they have VPN in cloud, customer says some time multicast work sometime doesn't. Tac has suggested to upgarade the image of LAN switch as the existing image only support IP PIM PASSIVE command on edge switch. But customer says why it works somtime and othertime stops working...
