Etherchannel configuration Dilema
ayokunles
hello Guys,
I am looking at an etherchannel configuration on a core switch and I have a this config on the etherchannel, is it right to have a trunk configuration on the etherchannel bundle. I thought it was supposed to be on the individual ports.
Also bear the individual ports also have trunk configurations.
Am not sure which is correct, because I have seen a working etherchannel config without the trunk config on the port-channel and it works.
I have found it better for L2 etherchannels to assign the physical ports to the channel-group and then
configure the port-channel with the trunk settings.
L2 etherchannel
1)Config default physical interfaces involved
2)assign channel-group and channel-group number on the physical interfacs and let  the port-channel be created automaticlly
3)create trunking encapsulation/mode directly in port-channel interface
4)reset physical interfaces "shut" "no shut"
This way you will find that the physical interfaces will inherit the config from the port-channel
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
