Etherchannel configuration
wlewis2488
Community Member
I just purchased 3 2960S-48FPD-L switches. I also ordered one (soon to be 2) 3850-24t-L. I am currently looking at purchasing an NM 4-1G module to go with the 3850. My intent in this is to configure etherchannels from the 3- 2960's front SFP ports, to the 4 port module I am getting for the 3850. I just want to make sure it is possible?
Wayne
Ruben Cocheno
yes it is possible.
regards
rc
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Jose Solano
Level 9
Level 9
 As long as the SFP you are going to use on both ends you should be fine, therefore just make sure of that.
