Etherchannel in switch multilayer packet tracer
YansetKiang
Hi experts this is my first post,
I´m practicing with SW multilayer in packet tracer, I´ve created a port-channel between 2 multilayer switches with the next commands
channel-group 1 mode desirable
but when i´m trying to assign an ip to this port channel with the command "no switchport" I can not do it and I´m getting this:
Switch(config)#int port-channel 1
Switch(config-if)#no switchport
% Incomplete command.
and also I get this message:
Switch(config-if-range)#no switchport
Command rejected (Port-channel): Either port is L2 and port-channel is L3, or vice-versa
So my question is, how can I assign an ip address to a port channel in a multilayer switch in packet tracer? is it possible to do that in PT?
Thanks in advance may be I´m doing something wrong.
InayathUlla Sharieff
You cant achieve this on Packet tracer.
But its possible or available in PT.
Inayath
campbech1
I just did this same setup in Packet Tracer 6.1.1 and it appears to work.
Default the configurations in each of your existing links, set the individual links as "no switchport" first, then place them into a port-channel, then enter into the port-channel interface and set the IP address.
interface Port-channel 1
  no switchport
  ip address 10.10.1.1 255.255.255.0
interface FastEthernet0/1
  no switchport
  no ip address
  duplex auto
  speed auto
interface FastEthernet0/2
  no switchport
  no ip address
  duplex auto
  speed auto
Hope that helps.
