03-06-2013 12:24 AM - edited 03-07-2019 12:05 PM
Can someone explain to me how this can be possible. Also, note that after a reload both interfaces went back to "connected" state:
asl2-enc05-02#sh int status
Port Name Status Vlan Duplex Speed Type
Gi0/21 asl2-43-02 gi0/11 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/22 asl2-43-02 gi0/12 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/23 asl2-enc05-01 gi0/ disabled trunk a-full a-1000 1000BaseX
Gi0/24 asl2-enc05-01 gi0/ disabled trunk a-full a-1000 1000BaseX
Po1 asl2-43-02 connected trunk a-full a-1000
Po2 asl2-enc05-01 connected trunk a-full a-1000
Fa0 disabled routed auto auto 10/100BaseTX
asl2-enc05-02#sh ru
interface Port-channel1
description asl2-43-02
switchport trunk native vlan 700
switchport trunk allowed vlan 200,202-205,212,214,218-220,222-230,233,234
switchport trunk allowed vlan add 237-240,242-244,246,247,302,303,306,315,316
switchport trunk allowed vlan add 318,325,330-342,346-348,600,700,702-704,706
switchport trunk allowed vlan add 709,716-718,720,725,726,796
switchport mode trunk
spanning-tree vlan 237,336-338 cost 10000
interface Port-channel2
description asl2-enc05-01
interface GigabitEthernet0/21
description asl2-43-02 gi0/11
channel-group 1 mode active
interface GigabitEthernet0/22
description asl2-43-02 gi0/12
interface GigabitEthernet0/23
description asl2-enc05-01 gi0/23
media-type internal
no cdp enable
channel-group 2 mode active
interface GigabitEthernet0/24
description asl2-enc05-01 gi0/24
media-type internal
no cdp enable
asl2-enc05-02#sh ver
Cisco IOS Software, CBS30X0 Software (CBS30X0-IPBASE-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 08:51 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01540000
ROM: Bootstrap program is CBS30X0 boot loader
BOOTLDR: CBS30X0 Boot Loader (CBS30X0-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc2)
asl2-enc05-02 uptime is 2 years, 13 weeks, 5 days, 5 hours, 4 minutes
System restarted at 12:39:11 CET Tue Nov 30 2010
System image file is "flash:cbs30x0-ipbase-mz.122-50.SE3/cbs30x0-ipbase-mz.122-50.SE3.bin"
cisco WS-CBS3020-HPQ (PowerPC405) processor (revision E0) with 131072K bytes of memory.
Processor board ID FOC1421T1XZ
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : A8:B1:D4:41:2A:80
Motherboard assembly number : 73-10340-12
Motherboard serial number : FOC142204P1
Model revision number : E0
Motherboard revision number : A0
Model number : WS-CBS3020-HPQ
System serial number : FOC1421T1XZ
Top Assembly Part Number : 800-27541-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : IPUIBDFRAA
Hardware Board Revision Number : 0x04
Switch Ports Model SW Version SW Image
* 1 24 WS-CBS3020-HPQ 12.2(50)SE3 CBS30X0-IPBASE-M
Configuration register is 0xF
asl2-enc05-02#sh etherchannel 2 detail
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Gi0/23
Port state = Up Mstr Assoc In-Bndl
Channel group = 2 Mode = Active Gcchange = -
Port-channel = Po2 GC = - Pseudo port-channel = Po2
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi0/23 SA bndl 32768 0x2 0x2 0x118 0x3D
Partner's information:
Port Flags Priority Dev ID Age key Key Number State
Gi0/23 SA 32768 a8b1.d441.2f00 9s 0x0 0x2 0x118 0x3D
Age of the port in the current state: 0d:02h:16m:47s
Port: Gi0/24
Local information:
Gi0/24 SA bndl 32768 0x2 0x2 0x119 0x3D
03-06-2013 12:53 AM
this seems ok. what is the configuration of other side. port configurations must be same in etherchannel interfaces. do it step by step
default inter range f0/23 - 24
shut
switchport trunk enc dot1q
no shut
03-06-2013 01:23 AM
Hi Jean,
As Mhendirli said kindly configure the parameters to be equal at both the ends to avoid ports going down or disabled.
Probably before rebooting the device you could have bounced the port-channel ports and had checked the status?
Next Time if in caes you see the same issue then collect and check the following information:
Make sure all vlans, trunk,native vlan parameters are matching on both the sides of Port-Channel.
We would need the following information:
1-Port channel configuration from both the end
2-Interface config belongs to that specific port channel
3-STP instance/status of the port-channel from both the end.
4-Latest logs from the device.
5- Shut and no shut the Port-Channel ports.
Inayath
*Plz rate the usefull posts.
