EtherChannel Load Balancing
johnlloyd_13
Level 11
Level 11
hi all,
we are using a 6509 with L2 etherchannel configured. could someone enlighten me how to read load distribution between GE links. is there a way to express this in percentage? thanks in advance!
6500#show etherchannel port-channel
                Channel-group listing:
Group: 2
                Port-channels in the group:
Port-channel: Po2
Age of the Port-channel   = 1025d:04h:08m:47s
Logical slot/port   = 14/1          Number of ports = 1
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     FF     Gi3/1    On    8
Time since last port bundled:    647d:21h:46m:49s    Gi4/16
Time since last port Un-bundled: 641d:06h:08m:39s    Gi4/16
Group: 3
Port-channel: Po3
Logical slot/port   = 14/2          Number of ports = 2
Protocol            =    -
  0     55     Gi3/16   On    4
  1     AA     Gi4/1    On    4
Time since last port bundled:    208d:00h:01m:40s    Gi4/1
Time since last port Un-bundled: 208d:00h:17m:15s    Gi4/1
Group: 4
Port-channel: Po4
Age of the Port-channel   = 1025d:04h:08m:48s
Logical slot/port   = 14/3          Number of ports = 2
Protocol            =    -
  1     55     Gi3/4    On    4
  0     AA     Gi3/5    On    4
Time since last port bundled:    184d:12h:17m:09s    Gi3/5
Time since last port Un-bundled: 184d:12h:23m:04s    Gi3/5
Peter Paluch
Hello John,
As naive as it may seem, I would simply have a look at the input/output counters in the show interfaces command output (see the counters for the appropriate physical interfaces that are bundled in an EtherChannel). I am not sure if there is any command that would directly show you the percentage of traffic distribution over an EtherChannel bundle but I guess the counters in show interfaces will provide you with the basic data to compute the ratios yourself.
Best regards,
Peter
Peter Paluch
Hello John,
Best regards,
Peter
hi peter,
makes sense to me. guess i would need to check manually. thanks for your help!
