Etherchannel mode on question
Wilson Kwok
Hello all,
I'm trying to setup etherchannel between two layer2 swtich in Cisco Packet Tacker, two switch fa0/1 and fa0/2 for etherchannel with trunk (mode on), and fa0/3 connected PC with access vlan 10.
But show etherchannel port both ports is down, can someone help ?
Renan Abreu
Can you send what you configured?
Renan Abreu
It should be a pretty simple task, just do "channel-group x mode on" on both sides, make sure physical and logical interfaces are "no shut"
The sample config per port shud b like this:
interface fa0/1
switchport mode trunk
switchport trunk allowed vlan 10
channel-group 1 mode on
Once u do it on per port per switch it will automatically create port channel 1 (since channel-group is 1 here) on both the switches.
Regards.
