Missing a piece for devices to fully communicate between VLANs
bull_thumper
Greetings!
Well, I’ve been tossed into the fire and have spent the past few days reviewing these and other forums. Even though I am well beyond my comfort level, some progress has been made, there is probably a tiny piece that is preventing me from completing my task.
First, the goal is to use an SG300-20 to allow a Windows computer on either VLAN 1 or VLAN 22 to communicate with proprietary devices on VLANs 21 and 22, all numbered after the third octet of their IP address. (Eventually, on each VLAN will be a consumer router that will have multiple devices.) These devices use UDP ports 50500 and 50501 and TCP port 50502.
So I have created VLANs 21 and 22 on the “Create VLAN” page and set their IP address on the “IPv4 Interface” page to
VLAN 1 to 192.168.13.123/24
VLAN 21 to 192.168.21.1/24
VLAN 22 to 192.168.22.2/24
Next I have attempted to assign Port VLAN Membership which is probably where my problem is. (I’ve even locked myself out of the switch a few times requiring a reboot.) My current Port VLAN Membership table has these relevant entries:
GE1 [device on VLAN 21] is GENERAL mode, 1T, 21UP
GE2 [device on VLAN 22] is GENERAL mode, 1T, 22UP
GE4 [computer on VLAN 22] is GENERAL mode, 1T, 22UP
GE6 [computer on VLAN 1] is TRUNK mode, 1UP, 21T, 22T
GE19 [router on VLAN 1] is TRUNK mode, 1UP
“show vlan tag” indicates (condensed):
Vlan       Name                   Ports                Type     Authorization
1          1                 gi1-20,Po1-8           Default      Required
21         21                   gi1,gi6            permanent     Required
22         22                 gi2,gi4,gi6          permanent     Required
“show interfaces switchport ge 1” returns (and GE2 returns the same except for referencing VLAN 22):
Port : gi1
Port Mode: Trunk
Gvrp Status: disabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 21
Port is member in:
Vlan               Name               Egress rule Port Membership Type
 1                  1                   Tagged           System
 21                 21                 Untagged          Static
(Forbidden VLANS and Classification rules were blank and deleted for brevity.)
“show interfaces switchport ge 6” returns
Port : gi6
Port Mode: Trunk
Ingress UnTagged VLAN ( NATIVE ): 1
Port is member in:
 1                  1                  Untagged          System
 21                 21                  Tagged           Static
 22                 22                  Tagged           Static
(Again, forbidden VLANS and Classification rules were blank and deleted for brevity.)
  • The device on GE1 has an IP of 192.168.21.3/24 and a gateway of 192.168.21.1
  • The device on GE2 has an IP of 192.168.22.3/24 and a gateway of 192.168.22.1
  • The computer on GE4 has an IP of 192.168.22.4/24 and a gateway of 192.168.22.1
  • The computer on GE6 has an IP of 192.168.13.120/24 and a gateway of 192.168.13.1
  • The SG300-20 has an IP of 192.168.13.123
  • On GE19 is a Cisco Linksys EA3500 router
I'm thinking that my error must be in either the gateways or the Port VLAN Membership with regards to tagging or PVID, but I'm not sure. I have tried many combinations and learned how to reboot the switch from the console communications port very well. (Thankfully it reboots in the last known good state.)
In fact, in some combinations, the computer and devies can see UDP broadcast packets but not respond back to a specific IP address.
If anyone could offer any tips or suggestions as to where I might have gone astray or something that I have not encountered, I would be most appreciated.
Naturally, if the SG300-20 is not capable of this, or additional hardware is required, then recommendations are requested.
Also, I have tried for format my query for clarity and hope I provided everything that is needed. Naturally, if I am missing something here, please do not hesitate to ask for further information.
DG
21 Replies 21
Hello
All what you are explaing comes down to " inter-vlan routing" - now I am ot familer with this type of switch however it does seem to be layer 3 comaptible.
So what is requried is to enable  ip routing.
Basically you create the svi interfaces as you have posted = vlan 1,21,22 ( the ip addresses of these switch virtual interfraces will become the  Default Gateway for end hosts on that particuler vlan, and with ip routing enabled also you should be able to communicate between all vlans.
res
Paul
Kind Regards
Paul
Thank you for your reply, Paul.
What you say makes sense but will take me a bit of study and figure out the practical side.
I am looking at the IPv4 Static Routes and it has three entries for 192.168.13.0, 192.168.21.0 and 192.168.22.0, all /24 and the "Route Type" is defined as "Local".
"show ip route conn" returns:
switch-sg300-20(config)#do sh ip route conn
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding:          enabled
Codes: C - connected, S - static, D - DHCP
C  192.168.13.0/24    is directly connected                        vlan 1
C  192.168.21.0/24    is directly connected                        vlan 21
C  192.168.22.0/24    is directly connected                        vlan 22
Is that what you are referring to or is there more that I must do ?
DG
I am not familiar with SG300 series, but your route table looks correct. You have 3 local subnets and as long as IP routing is enabled on your device and each host has a correct default gateway, you should be able to ping from one host to the others. Also, make sure your PCs/Laptop don't have any firewall software installed, if they do the software prevent them from pinging or being pinged. Does the GUI has an option for turning on routing?
Well, the command "show ip route static" shows
switch-cg300-20(config)#do show ip route static
According to this, IP Forwarding is enabled. Is that the same as the routing you refer to?
What is curious to me is that the list is empty there and yet the GUI shows the values I posted earlier. Hmmmm....
And, yes, I agree about the firewalls and am absolutely certain that none are present.
DG
Yes, I think, IP forwarding mans IP routing and it is enabled.
Very interesting output sh ip route conn vs sh ip route static
It seems to me that you have to do something else for the static routes to show up on the routing table.  When you trace from one host, to another, how far does the trace make it? It makes it harder for us to help you since most of us on this forum are not familiar with this switch series.
Already Reza, I had typed out a whole response and boom, "Host unreachable." You'll understand why in a moment.
To recap what I tried while trying to control my excitement...
I did a tracert to 192.168.23.3, a known device, but the first hop was to the router at 192.168.13.1 and then to the outside world via my ISP. I suppose that trace is still bouncing around somewhere!
So I thought, that makes total sense since .13.1 is the gateway of my computer and so I thought that since VLAN 1 was .13.123, I should change it. So I did but it didn't work. The tracert stopped right there and reported "Destination host unreachable."
Thinking that the gateway for a VLAN other than 1 is .x.1, I need to try this on a PC on one of the other VLANs or maybe create a VLAN 2 just for this purpose.
(At this point, I was typing my response and click Submit but I did it before I put the gateway back and lost all of my text!)
So, give me a little bit to try another computer and put it on another VLAN and see what I get.
Maybe my ultimate solution is to put the Cisco Linksys wireless router on its own VLAN? Is that a recommended procedure?
Be right back...  (Getting excited again!)
Can you also put a quick drawing together showing how every device (switch, wireless, Internet) is connected?
These are the connections on the Cisco SG300-20 switch:
This is the diagram you requested:
Nice picture!
Ok, lets figure out why you can't ping from one vlan to another first.
Are all the ports connected to the SG-300 switch configured as access port?
In one of your post, I saw vlan 21 and 22 tagged (trunked) can you configure both ports as access for vlan 21 and 22 and see if you can ping from one tempest to another?  Also, is there a way you can login to the device and enable "IP routing"?
I just confirmed that I cannot do this.
Using GE 1 for my example, which was configured as 21UP and 23T in Trunk mode, I tried to change to Access mode but it would not let me returning the error "Port gi1, belongs to a wrong number of VLANs."
So I went to Port VLAN Membership and removed 23T and returned to Interface Settings and was now able to change it to Access mode.
Then I returned to Port VLAN Membership and tried to re-add 23T but in Access mode, it only lets me have a single Untagged PVID entry. The error is "Interface can be added as untagged to only a single VLAN."
Regarding IP Routing, I thought we ascertained that IP routing was enabled or is there something else I should be looking for ?
Answer last first:
I am just guessing and I think it make sense that IP forwarding means IP routing since I am not familiar with this platform.
As for the other issue, since we only have one device connected to vlan 21 and one to vlan 22, so for test we just need to add the specific port to specific vlan as access port and see if you can ping between the 2 vlans.
once we get the communication between these 2 vlans established, we can then move on to the other tasks
As for the other issue, since we only have one device connected to vlan 21 and one to vlan 22...
In my last post, I was using an interface (in that case GE 1) to change the mode to Access as you requested. It was in Access mode that I was unable to assign multiple VLANs to a single interface.
I can set multiple interfaces to the same VLAN in which case all common devices and the software works perfectly.
Ok, let clarify,
In your chart port assignment the top tempest base is connected to port gi0/1 (vlan 21) and the next tempest is connected to gi0/2 (vlan 22).  Now, each tempest is in a separate vlan/subnet right? ok, so gi0/1 should belong to vlan 21 as access port and gi0/2 belong to vlan 22 as access port.
so far so good right?
ok, now each tempest should be able to ping their gateway which is the switch and if IP routing (forwarding )is enabled on the switch the tempests should be able to ping each other.
Is that the case?
