02-04-2013 03:42 AM - edited 03-07-2019 11:29 AM
Hi All,
i have already created the port-channel but i cannot assign the gig interface to the channel group.
02-04-2013 04:26 AM
Hi Fadil,
Could you please let us know few things here:
1) What is the other end device you are trying to make the port-channel?
2) Can you paste the config from both the devices( Port channel config will do)?
3) What error do you get when you try to put the Gig interface into port-channel?
Below is the link which can help is some way on etherchannel on ISR routers:
https://docs.google.com/viewer?a=v&q=cache:LgO31aH4e5wJ:www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_white_paper0900aecd806f698a.pdf+&hl=en&gl=in&pid=bl&srcid=ADGEESiv6fHK3EUzSmAzcGgMZYBxX5HFwzEkmrLpP6LD9XxKBEkllSr1N-Cu0vRqPauRnWxFqv_3BAkS...
Inayath
Log in to Community
