Etherchannel PAGP Problem
farzancisco
Frequent Visitor
Frequent Visitor
Hello my friends!
I created 1 ether channel between 4503E and 2960 TTL on 2 ports.
Ether channel ist up but can not load balancing on 2 port. all traffics pass 1 port. The real bw monitor attached.
where is my problem?
2 Accepted Solutions
brselzer
Are you doing a file transfer from the same source to the same destination? Etherchannel does per flow load balancing and not per packet. Might be expected if you only have one source and one destination.
Hope that helps!
-Bradley Selzer
CCIE# 60833
This is what I mentioned earlier about single host to single host. The load-balancing is done per flow, not per packet. Therefore this single flow will only use one link in a port-channel.
cheers,
Seb.
13 Replies 13
Seb Rupik
Hi there,
This is most likely an issue with the load balancing algorithm used on either end of the link:
show etherchannel load-balance
...you need to understand the type of traffic flows traversing the link to choose the best algorithm.
cheers,
Seb.
thanks Rupik! i changed load balance algorithm on both switches to src-dst-ip, but still there is a problem. I tested other load balance algorithm on both switches!
Can you share the output of sh etherchannel from both ends?
Also, what is the src/dest composition of the traffic over the etherchannel. As an extreme example, is it a single host to single host? An entire subnet to a single host? A range of subnets sending traffic off to the internet?
cheers,
Seb.
2960-u7#sh etherchannel
Channel-group listing:
Group: 1
Group state = L2
Ports: 2 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: PAgP
Minimum Links: 0
4503-core-switch#sh etherchannel
Group: 1
Group state = L2
Protocol: PAgP
Group: 2
Group state = L2
Protocol: PAgP
Group: 3
Group state = L2
Protocol: PAgP
Group: 4
Group state = L2
Protocol: PAgP
Group: 5
Group state = L2
Protocol: PAgP
Group: 6
Group state = L2
Protocol: PAgP
Group: 7    ------------->> to 2960
Group state = L2
Protocol: PAgP
Group: 11
Group state = L2
Ports: 4 Maxports = 8
Protocol: LACP
Group: 12
Group state = L2
Protocol: LACP
Group: 13
Group state = L2
Protocol: LACP
Group: 41
Group state = L2
Ports: 3 Maxports = 8
Protocol: LACP
Group: 42
Group state = L2
Protocol: LACP
Group: 43
Group state = L2
Protocol: LACP
load balance algorithm is src-dst-ip in both switches.
im using a few subnet in my network. this subnet for test is : on client side : 172.31.12.0/24 and on server side is 192.168.25.0/24
client subnets sending traffics to internet.
Jaderson Pessoa
Hello, as Rupik said, maybei it is a loabalance algorithm, you can try change it.
Check this link with some exemples: https://community.cisco.com/t5/switching/3750x-stack-changing-etherchannel-load-balance-configuration/td-p/2062317
Jaderson Pessoa
*** Rate All Helpful Responses ***
thanks Pessoa! But still there is a problem with ether channel. still pass all traffics on 1 port.
Please, input here.
show etherchannel and show interface gi1/0/x (all ports in bundle)
Thanks.
Jaderson Pessoa
i wrote show etherchannel in the top.
4503-core-switch#show interfaces gigabitEthernet 2/47
GigabitEthernet2/47 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0011.21e1.9cce (bia 0011.21e1.9cce)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input 00:00:13, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 64497
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 264000 bits/sec, 36 packets/sec
415284937 packets input, 143001564621 bytes, 0 no buffer
Received 4908216 broadcasts (2939647 multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
496858041 packets output, 443623736738 bytes, 0 underruns
0 lost carrier, 0 no carrier
4503-core-switch#show interfaces gigabitEthernet 3/47
GigabitEthernet3/47 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0011.21e1.6b1e (bia 0011.21e1.6b1e)
Last input 00:00:15, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 11433
5 minute input rate 45000 bits/sec, 36 packets/sec
5 minute output rate 81000 bits/sec, 19 packets/sec
241171124 packets input, 70445382878 bytes, 0 no buffer
Received 3896870 broadcasts (3156775 multicasts)
502804639 packets output, 545082123255 bytes, 0 underruns
2960-u7#show interfaces gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.0c5e.e931 (bia 001b.0c5e.e931)
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:11, output hang never
5 minute input rate 259000 bits/sec, 36 packets/sec
5 minute output rate 2000 bits/sec, 3 packets/sec
1039634412 packets input, 1037913899097 bytes, 0 no buffer
Received 126901067 broadcasts (97923696 multicasts)
14 input errors, 5 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 97923696 multicast, 0 pause input
770108611 packets output, 265128136012 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
2960-u7#show interfaces gigabitEthernet 0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.0c5e.e932 (bia 001b.0c5e.e932)
Keepalive not set
Last input 00:00:13, output 00:00:08, output hang never
5 minute input rate 72000 bits/sec, 20 packets/sec
5 minute output rate 36000 bits/sec, 33 packets/sec
502798159 packets input, 545079999948 bytes, 0 no buffer
Received 28543471 broadcasts (8801912 multicasts)
0 watchdog, 8801912 multicast, 0 pause input
241163676 packets output, 70444041858 bytes, 0 underruns
4503-core-switch#show interfaces port-channel 7
Port-channel7 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0011.21e1.6b1e (bia 0011.21e1.6b1e)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
Full-duplex, 1000Mb/s, media type is N/A
Members in this channel: Gi2/47 Gi3/47
Last input 00:13:55, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 66404
5 minute input rate 33000 bits/sec, 33 packets/sec
5 minute output rate 341000 bits/sec, 60 packets/sec
640078444 packets input, 207634306713 bytes, 0 no buffer
Received 8562131 broadcasts (5932974 multicasts)
975362652 packets output, 965665228936 bytes, 0 underruns
2960-u7#show interfaces port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 001b.0c5e.e932 (bia 001b.0c5e.e932)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
Members in this channel: Gi0/1 Gi0/2
Last input 00:00:00, output 00:00:06, output hang never
5 minute input rate 332000 bits/sec, 57 packets/sec
5 minute output rate 32000 bits/sec, 32 packets/sec
975362326 packets input, 965665927212 bytes, 0 no buffer
Received 118859951 broadcasts (84875519 multicasts)
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 84875519 multicast, 0 pause input
640079296 packets output, 207634419650 bytes, 0 underruns
brselzer
Hope that helps!
-Bradley Selzer
CCIE# 60833
source address is 172.31.12.159 destination address is 192.168.25.131
and i want to copy file from source to destination.
Like the picture. i attached.
cheers,
Seb.
thanks Rupik and thanks brselze!
Problem resolved.
So the load balance base on total traffic on all source and destination, not from 1 source and 1 destination.
i tested with 2 source (last bit on sources is different after xor) on 1 destination. and hash algorithm is src-dst-ip and load balancing was done.
Correct. Each flow is evaluated by the hashing algorithm as it is about to be forwarded over the etherchannel. It will continue to use that member link for the duration of the flow. It is quite likely that in a production network you will never achieve perfect load-balancing across member links.
cheers,
Seb.
