EtherChannel / Port Groups / Switch trunk/LAG | 2960S
Mark^
Hi all,
We recently upgraded to a some 48 port 2960S Catalysts and I have setup EtherChannel between the two of them.  I'm no expert here, so I just want to get some feedback on how I configured it.  I'm not having any noticable issues with the config, but I'd like to know I did it right (or wrong) and the way it "should" be.
I grouped two ports, and here are the snippets from my config:
interface Port-channel5
description Switch Trunk LAG
switchport mode trunk
interface GigabitEthernet1/0/47
description Switch LAG
channel-protocol lacp
channel-group 5 mode active
interface GigabitEthernet1/0/48
I just read something that made me wonder if the post should be mode access instead of mode trunk, which is what prompted me to post here to the experts.
Thanks!
Mark
JohnTylerPearce
Level 7
Level 7
There doesn't seem to be anything wrong with it.
You can create it as a trunk, access port, or a L3 port, whatever floats your boat.
I would also look at port-channel load-balancing' This is based on a hash of the following.
src-mac
dst-mac
src-dst-mac
src-dst-ip
etc etc. Just know what kinda  traffic is going through.
You can configure load balancing by 'port-channel load-balance ?'
Also, run the command 'show etherchannel summary'
It should be in a SU state.
11 Replies 11
JohnTylerPearce
Level 7
Level 7
src-mac
dst-mac
src-dst-mac
src-dst-ip
Thanks.
So, do I need "channel-protocol lacp"?  I know EtherChannel and LACP are similar but Etherchannel is Cisco's proprietary if I understand correctly.  So, if I take out the LACP line, does it run in proprietary EtherChannel?  Better?  Same?  And also, what benefit/side effects would I get if the switchports were in access mode?
I've basically got all my servers on one switch and all myworkstations on the other with tons of traffic (windows file shares, sql, etc).  10 servers, 30 workstations.  And am looking for the best performance with what I have.
Mark
Actually, lacp is industry standard and pagp is cisco-proprietary. Etherchannel is a term used to describe the technology used. Technically, you don't need to specify lacp, but you'd configure it as a "channel-group mode active" or "channel-group mode passive" to enable lacp negotiation.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Ok, cool.  So what I have is good and there aren't really any changes that would have a substantial impact on performance.
Appreciate all the feedback!
Mark
Also just a FYI, I believe if you change the Etherchannel load balancing options, you will have to re-create the Etherchannel.
Anyway, glad we were able to help you out.
Hi John,
No, that is not necessary. You can change the load balancing mechanisms on the fly. You would need to recreate an EtherChannel if you changed the mode between Layer2 and Layer3.
Best regards,
Peter
I think I've been reading some wrong documentation...... Freakin Cisco.
I've actually made the changes on the fly, and ran the 'test' command, but never technically investigated the traffic.
Peter, is it possible to have different load-balancing algrithms on each side?
Sorry for the questions Peter, some times documentation can be confusing.
John,
First of all, don't be sorry for any questions here! Your questions are absolutely appropriate, and after all, this entire forum is all about questions (and hopefully, answers)
Perhaps it was necessary on some selected platforms but my knowledge is that the load balancing algorithm can be changed on the fly without recreating the EtherChannels.
Yes, absolutely, and in fact, it is often desired, especially when the load balancing mechanism takes only a single address field into account.
Best regards,
Peter
John,
What is the test command you mention above?  Is that only for load balancing?
Mark
Yeah, it's really only used to test load balancing.
If you type in 'test ?' I belive it's under 'test etherchannel' or something lilke that.
Thanks.  All this info has been helpful.
Much apprecaited guys!
Mark
