Etherchannel Port state=Down Not-in-Bndl
r.bochenek
I have a problem with the interface in Etherchannel.
The Etherchannel is set up between stacked 4x2960 and 4x3750 switches.
The link has two ports on each side, but only one is active.
2960:
Group Port-channel Protocol Ports
3 Po3(SU) - Te3/0/2(P) Te4/0/2(D)
interface TenGigabitEthernet3/0/2
switchport mode trunk
switchport nonegotiate
channel-group 3 mode on
interface TenGigabitEthernet4/0/2
3750:
3 Po3(SU) - Te3/1/2(P) Te4/1/2(D)
interface TenGigabitEthernet4/1/2
interface TenGigabitEthernet3/1/2
what can be done to activate these ports?
I send you message check it
@MHM Cisco World - Do you have any particular reason(s) for not sharing content and knowledge in the community ; being one of it's core purposes (?)
 Tx - M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
r.bochenek
It turned out that the optical fiber was damaged, thanks for the suggestions.
