Etherchannel problem for 6500 VSS
Sanjay Shaw
Hello Team,
Could anyone suggest if I use lots of etherchannel configuration running between my access(4500) and DS(6500)  may create any etherchannnel issue. As in my enviroment I am experiecing my access switch bundled interfaces getting down and we have to manually replug the cable to up the etherchannel bundle.
Is there any oversubscription happenning in my 6500 chasis which causing the bundle to get in down state. Logs at both the end only suggest for the interface flaps.
Note: 6500 is in VSS.
6506-E#  sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 27
Number of aggregators:           27
Group  Port-channel  Protocol    Ports
1      Po1(RU)          -        Te1/5/4(P)     Te1/5/5(P)
2      Po2(RU)          -        Te2/5/4(P)     Te2/5/5(P)
3      Po3(SU)          -        Gi1/1/3(P)     Gi2/1/3(P)
10     Po10(SU)         -        Gi1/1/5(P)     Gi2/1/5(P)
11     Po11(SU)         -        Gi1/1/6(P)     Gi2/1/6(P)
14     Po14(SD)         -
17     Po17(SU)         -        Gi2/1/4(D)     Gi2/2/14(P)
19     Po19(SU)         -        Gi1/1/14(P)    Gi2/1/14(P)
20     Po20(SU)         -        Gi1/1/15(P)    Gi2/1/15(P)
21     Po21(SU)         -        Gi1/1/16(P)    Gi2/1/16(P)
22     Po22(SU)         -        Gi1/1/17(P)    Gi2/1/17(P)
23     Po23(SU)         -        Gi1/1/18(P)    Gi2/1/18(P)
24     Po24(SU)         -        Gi1/1/19(P)    Gi2/1/19(P)
25     Po25(SU)         -        Gi1/1/20(P)    Gi2/1/20(P)
26     Po26(SU)         -        Gi1/1/21(P)    Gi2/1/21(P)
27     Po27(SU)         -        Gi1/1/22(P)    Gi2/1/22(P)
28     Po28(SU)         -        Gi1/1/23(P)    Gi2/1/23(P)
29     Po29(SU)         -        Gi1/1/24(P)    Gi2/1/24(P)
30     Po30(SU)         -        Gi1/2/1(P)     Gi2/2/1(P)
31     Po31(SU)         -        Gi1/2/2(P)     Gi2/2/2(P)
32     Po32(SU)         -        Gi1/2/3(P)     Gi2/2/3(P)
33     Po33(SU)         -        Gi1/2/4(P)     Gi2/2/4(P)
34     Po34(SU)         -        Gi1/2/5(P)     Gi2/2/5(P)
35     Po35(SU)         -        Gi1/2/6(P)     Gi2/2/6(P)
36     Po36(SU)         -        Gi1/2/7(P)     Gi2/2/7(P)
37     Po37(SU)         -        Gi1/2/8(P)     Gi2/2/8(P)
38     Po38(SU)         -        Gi1/2/9(P)     Gi2/2/9(P)
Wilson Bonilla
Level 3
Level 3
Hello Sanjay
Oversubscription may happen at linecard and ASIC level, But I don't  think oversubscription has anything to do with the problem your switch is experiencing.
In regards to oversubscription here is an example
WS-X6724-SFP
Port ranges per port group: 1-12, 13-24
Oversubscription rate 1:12 (One ASIC every 12 ports)
Look at this link for further information about oversubscription in each module.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Module_Installation/Mod_Install_Guide/02ethern.html#wp1040314
The VSS supports up to 512 Etherchannels combined the total amout of regular etherchannels and MEC.
Wilson Bonilla
Level 3
Level 3
Hello Sanjay
WS-X6724-SFP
