Etherchannel showing down (SD) and ports are in "I" stand alone state
gautham257
Netapp server is connected to switch 6500 via trunk.
I configured a portchannel but it showing as down.take a look ar below output..
interface Port-channel248
description Netapp-server-1 po248
switchport
switchport trunk allowed vlan 903
switchport mode trunk
switchport nonegotiate
no ip address
no shut
interface GigabitEthernet3/33
description server-1
  switchport
no ip address
speed 1000
udld port aggressive
spanning-tree portfast
channel-group 248 mode active
no shut
interface GigabitEthernet4/33
description cnndcfasp002a-e5d
  switchport
no ip address
speed 1000
no shut
Switch-6500#sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
Number of channel-groups in use: 5
Number of aggregators:           5
Group  Port-channel  Protocol    Ports
248    Po248(SD)       LACP      Gi3/33(I)  Gi4/33(I)
#sh etherchannel detail
Group: 248
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
                Ports in the group:
Port: Gi3/33
Port state    = Up Sngl-port-Bndl Mstr Not-in-Bndl
Channel group = 248         Mode = Active      Gcchange = -
Port-channel  = null        GC   =   -         Pseudo port-channel = Po248
Port index    = 0           Load = 0x00        Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi3/33    SA      indep     32768         0xF8      0xF8    0x321       0x7D
Age of the port in the current state: 0d:02h:04m:58s
Port: Gi4/33
Local information:
Gi4/33    SA      indep     32768         0xF8      0xF8    0x421       0x7D
                Port-channels in the group:
Port-channel: Po248    (Primary Aggregator)
Age of the Port-channel   = 7d:16h:30m:16s
Logical slot/port   = 14/3          Number of ports = 0
Port state          = Port-channel Ag-Not-Inuse
Protocol            =   LACP
Any one please let me know what is the issue here...
Gautham
6 Replies 6
lmediavilla
Its because it doesn't see LACP  messages on the other side or its connected to two different devices. Or to the same devices but with a LACP link and a different LACP link or a not LACP link
I've had that problem so many times.
Thanks for the reply...
So the problem might be on NETAPP server right ??? i mean netapp server need to configure with same LACP configs that i have used on 6500 right ???
Exactly, the 6500 config is fine, probably the NETAPP is not active or passive and it's just ON that won't work
show lacp 248 neighbor will show if you have a neighbor and if the LACP id is the same on both ports
Core1#sh lacp 2 neighbor
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 2 neighbors
Partner's information:
          Partner Partner   LACP Partner  Partner   Partner  Partner     Partner
Port      Flags   State     Port Priority Admin Key Oper Key Port Number Port State
Gi1/7/10  SA      bndl      32768         0x0       0x1      0x11A       0x3D
Gi2/7/10  SA      bndl      32768         0x0       0x1      0x31D       0x3D
cheers
i see below ouput..
So what does below output mean ??
switch-6500#sh lacp 248 neighbor
Channel group 248 neighbors
Gi3/33    SP      indep     0             0x0       0x0      0x0         0x0
Gi4/33    SP      indep     0             0x0       0x0      0x0         0x0
indep  Means independed state (not on lacp etherchannel)
bndl bundled (that is good)
cheers
danunjayab
i have too this problem with port-channel
I am using 2 port channel 14&123
14 is connected to 2 ports(4/1 and 4/3)
123 is connected to 4 ports(2/32-33,2/35,2/38)
But here is the problem is in port-channel 14 i have facing problem with one port is bonding and second port is going to independent, Why this happened, I want port-channel 14 same like port channel 123, Both ports have to come in banding not independent
Gi4/1     SA      bnd1
Gi4/3     SP      indep
14 Po14(SU)       LACP      Gi4/1(P)       Gi4/3(I)
123 Po123(SU)   LACP      Gi2/32(P)     Gi2/33(P)    Gi2/35(P)    Gi2/38(P)
