etherchannel- stack 3750X
a.aitkaddour
Community Member
I have two stacks 3750X on two different sites with two links L_2_L, and I want to configure the port channel to aggregate the two links.
Site A        Site B
3750X -A1 --------------------------------------(          )--------------------------------------- 3750X -B1
                                                      (  L-2-L )
3750X -A2 --------------------------------------(          )--------------------------------------- 3750X -B2
below the configuration that I have put the two stacks.
site A
interface Port-channel5
description Etherchannel group entre le stack 3750X-A et Switch Lan_2_Lan
switchport trunk allowed vlan 11,12,999
switchport mode trunk
switchport nonegotiate
speed 100
interface GigabitEthernet1/0/15
description la liaison LAN_2_LAN
speed 100
duplex full
channel-group 5 mode active
interface GigabitEthernet2/0/15
speed 100
duplex full
channel-group 5 mode passive
Site B
speed 100
speed 100
duplex full
speed 100
duplex full
but the problem is only one link is Bundeled in channel group, see below
Group  Port-channel  Protocol    Ports
5      Po5(SU)         LACP      Gi1/0/15(I) Gi2/0/15(P)
how can i resolv this problem?
Best regards
9 Replies 9
Fraydoon Razazi
Level 3
Level 3
On site A you have:
change the channel-group 5 mode active or remove the switchport nonegotiate
I changed the config, but the problem persist.
Best regards
InayathUlla Sharieff
Hi ,
I just tested the similar configuration on my devices and it worked fine.
Please find below my configuration:
Sw1---F0/1 & f0/2---connected to Sw F0/1& f0/2
SW1
interface FastEthernet0/1
interface FastEthernet0/2
interface Port-channel 5
SW2:
Outputs of show etherchannel summary:
Switch1 #show etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
5      Po5(SU)           LACP   Fa0/1(P) Fa0/2(P)
2)
Switch2#show etherchannel summary
        d - default port
Inayath
*Plz rate if this is helpfull.
If still not working then do the following on both the devices:
1- Default the interfaces. ([config]# default int GigabitEthernet1/0/15 & 2/0/15)
2- shut the interface
3- configure the ports with your port configuration ( Make sure you have Channel-group Active -Active at both the side).
4-configure the port-channel on both the devices.
5- Re-enable the port @ both the ends.
This should work.
REgards
Inayath
Fraydoon Razazi
Level 3
Level 3
Actually it is not a good practice to use nonegotiate with LACP, (active active on both side) I would remove all the nonegotiate from all the interfaces including portchannel.
Fraydoon
Have u check Cisco Recomended Setting.  Please see this
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml
** Rate all Helpful Posts **
Jawad
a.aitkaddour
Community Member
Hi All,
thank you for your answers.
I already applied the same comments that you have communicated to me and I followed the same documents that you mentioned.
and the problem persist.
to remind you, I used active mode for all interface on both sites. and I have two links L_2_L with optical fbre
I noticed that with the current setup I have the following result:
Site A        Site B
        (  L-2-L )
but when I permute the two fiber links I get the following result:
Site A        Site B
3750X -A1 --------\              /------------(            )--------------------------------------- 3750X -B1
                               \-------- / ------\        (  L-2-L )
3750X -A2 -----------------/           \------(            )--------------------------------------- 3750X -B2
5      Po5(SU)         LACP      Gi1/0/15(P) Gi2/0/15(I)
as you see the status of interface changes when I change the location of links, it is possible that the problem was related a links L_2_L?
Best regards
Yes there could be possiblity.
Kindly try changing the cable and sfp ports and test the same.
Inayath
Jayden Le
Community Member
I notice you have the Port channel on both site as active, is there a reason why you do this? Reason why i ask is because usually port channel mode should be either
     1. On - On
     2. Active-Passive
     3. Passive-Active
I would suggest you recreating the port channel and hard code both end as ON instead of using negotiation. I have a very similar setup and it works for me.
