Etherchannel using Cisco 2960G with Cisco 3750
Lavanholy
I have a core switch Cisco 3750G (1 No) and Cisco 2960G (7 Nos).I have successfully created " Etherchannel between Cisco 2960 G (6 Nos) to Core Cisco 3750,when I am trying to configure the ether channel between the 7th Cisco 2960 G to the core cisco 3750,it is not allowing me to....As the Cisco document the Cisco 2960 G will support upto 6 etherchannel.Is there any way to configure nore than 6 ether channel.Please guide us.
Lavanholy
satish_zanjurne
Level 4
Level 4
NO of etherchannel is limited to 48 on 3750 as per IOS 12.2(25)SEE
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swethchl.html
For 2960G it is limited to 6 as per IOS 12.2(25)SEE.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swethchl.html#wp1275881
Best option would be to have 2 cores, and put one uplink from 2960G to each 3750 without etherchannel.
So you have core redundancy at 3750.
And you have uplink redundancy at 2960G.
