08-20-2008 12:18 AM - edited 03-06-2019 12:54 AM
Hello
I am trying to establish an etherchannel based on LACP between 3750 and 6500.
The problem is that the channel do not want to establish. On 3750 side it shows
6 Po6(SD) LACP Gi1/0/1(H) Gi1/0/2()
and on 6500 side it shows
Po6(SD) LACP Gi1/1(I) Gi1/2(I)
At the same time the 3750 switch has another channel already established with another 3750 and it works fine.
It looks like there is an issue between LACP on two platforms.
I am using 12.2(35)SE5 on 3750 and 122-18.SXF6 on 6500.
Does anybody have the same problem and could help me ?
Thanks in advance
Lukas
08-20-2008 01:24 AM
On the 6500 side it looks like the ports are in standalone mode which implies they don't have the same config.
Are you getting any log messages? Can you post the config?
Andrew.
08-20-2008 01:35 AM
Here you go.
From the 3750 side
interface GigabitEthernet1/0/1
description xxxxx
switchport trunk native vlan 299
switchport trunk allowed vlan 1
switchport mode trunk
logging event bundle-status
channel-group 6 mode active
interface Port-channel6
description xxxxx
From the 6500 side
interface GigabitEthernet1/1
description xxxxxx
switchport
udld port aggressive
channel-protocol lacp
description Gxxxxx
switchport
no ip address
The only log messages I get are:
On 3750 side
344014: Aug 20 11:31:26.101: %EC-5-UNBUNDLE: Interface Gi1/0/1 left the port-channel Po6
Aug 20 11:31:26.110: %EC-5-UNBUNDLE: Interface Gi1/0/1 left the port-channel Po6 (xxxx)
344015: Aug 20 11:31:30.086: %EC-5-BUNDLE: Interface Gi1/0/1 joined port-channel Po6
Aug 20 11:31:30.094: %EC-5-BUNDLE: Interface Gi1/0/1 joined port-channel Po6 (xxxx)
344016: Aug 20 11:31:35.454: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
From 6500 side:
The is no logs except the information that loopguard from time to time is blocking the port 1/1.
08-20-2008 03:32 AM
The udld port aggressive on the 6500 may be causing a problem if you don't have it on the 3750 which i don't see. On trunks/etherchannels the parameters have to be exactly the same . something to try , either pull udld off the 6500 or add to the 3750 and then check to make sure udld is working correctly. I have also found that bringing both ports at the same time sometimes helps.
08-20-2008 05:07 AM
It does not help.
08-20-2008 04:27 AM
I only see the config for one port at each end - are the other ports identically configured?
Also, can you post a "show etherchannel detail".
Andrew.
08-20-2008 05:16 AM
For now we left only one port in this port-channel of 6500 side (gi 1/2) and 3750 side (1/0/2)
On 6500 side:
Group: 6
Group state = L2
Ports: 1 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Gi1/2
Port state = Up Sngl-port-Bndl Mstr Not-in-Bndl
Channel group = 6 Mode = Active Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po6
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi1/2 SA indep 32768 0x6 0x6 0x102 0x7D
Age of the port in the current state: 0d:03h:41m:15s
Port-channels in the group:
Port-channel: Po6 (Primary Aggregator)
Age of the Port-channel = 13d:23h:49m:48s
Logical slot/port = 14/1 Number of ports = 0
Port state = Port-channel Ag-Not-Inuse
Protocol = LACP
On 3750 side:
Group: 6
Group state = L2
Protocol: LACP
Ports in the group:
Port: Gi1/0/2
Port state = Up Mstr Assoc In-Bndl
Port-channel = Po6 GC = - Pseudo port-channel = Po6
Local information:
Gi1/0/2 SA bndl 32768 0x6 0x6 0x2 0xD
Partner's information:
LACP port Oper Port Port
Port Flags Priority Dev ID Age Key Number State
Gi1/0/2 SA 32768 001e.7a82.5840 18s 0x6 0x102 0x75
Age of the port in the current state: 0d:00h:00m:14s
Age of the Port-channel = 13d:23h:50m:51s
Logical slot/port = 10/6 Number of ports = 1
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi1/0/2 Active 0
Time since last port bundled: 0d:00h:00m:16s Gi1/0/2
Time since last port Un-bundled: 0d:00h:00m:19s Gi1/0/2
08-20-2008 05:49 AM
So it's working OK now with just one port in the channel?
Andrew.
08-20-2008 06:59 AM
Unfortunately not. We have reduced numer of ports to check if it is a problem with the number of interfaces. But it seems not.
08-20-2008 10:54 PM
I have found that the problem occurs only when I use different native vlan than the default one on LACP etherchannel between 3750 and 6500.
When I have configured the LACP channel with the default native vlan I was able to stablish a LACP connection.
There is also no problem with establishing a trunk between those two platforms with the native vlan set to 299 without LACP etherchannel.
So it looks like there is some missmatch in the way the native vlan is processed on each platform and set in the LACP packets.
Lukas
