Etherchannel using LACP
Sukanta Biswas
Community Member
Could anyone please explain me whether I can create a port channel using LACP with two different ports from two different switches. The senario is below
i want to connect two servers (with daul NIC). lets say
switch_1 (port g0/5) to NIC_1 of server_1
switch_2 (port g0/5) to NIC_1 of server_2
switch_1 (port g0/7) to NIC_2 of server_1
switch_2 (port g0/7) to NIC_2 of server_2
please note that the switches (3550) are not stacked. Any suggestions/advice would be greatly appreciated.
Rgds
Sukanta
You would only be able to achieve what you seek by teaming the ports on the server side and connecting the the ports across the two switches.
Example:
Servers side
VIP: 10.1.1.7
NIC_1  -->  Switch 1
NIC_2  -->  Switch 2
You could make it work this way, but limitations of non-VSS switches will not allow this configuration via etherchannel.
6 Replies 6
Latchum Naidu
Hi Sukanta,
Yes, you can create port channel by using LACP between two different switches.
You can connect your servers two NIC's to switch and assign channel-group in this way you can have redundancy and load balance.
Please see the below link for more information.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094470.shtml
Please rate the helpfull posts.
Naidu.
Hi Naidu,
thank you so much for your prompt response. But I am trying to create a channel-group like below
switch_1 (g0/5) and Switch_2 (g0/5)------- one channel group
switch_1 (g0/7) and switch_2 (g0/7)------- another channel group
or is there any other best way i can create two channel group for load balance & redundancy purpose?
Much appreciated any advise.
Rgds
sukanta
Antonio Knox
Level 11
Level 11
You can create channel between two ports on different switches, but you cannot use two switches to configure a single etherchannel to one server.  This configuration you seek to make is only possible if you are running Cisco VSS (Virtual Switching System).  However, using your example:
This appears to be a reasonable configuration.  I assume you want to implement ehterchannel with added redundancy across the switches.  Is this the reason you want to make this configuration?
Message was edited by: Antonio Knox
Hi Antonio,
yes, you are right. i think, i mistyped the port. I exactly want to setup channel group as you mentioned considering redundancy. I would also want to set this layer 2 channel group.
Any suggestions, greatly appreciated.
Example:
Servers side
VIP: 10.1.1.7
NIC_1  -->  Switch 1
NIC_2  -->  Switch 2
Hi Sukata,
       I should not do that. Let me explain what it should be.
Server: Using LACP means that NIC1 and NIC2 should be Active/Active.
Switch: C3550 has no idea about LACP configuration on other switch.
Solution: Configure the Server to run Active/Standby aka fault tolerance. No need to configure anything on C3550.
Optional , Server : Active/Active mode.
1. Terminate Nic1 and Nic2 on the switch and then use LACP on both sides.
2. Using Cross-Stack Etherchannel on C3750 Stack. Two switches can be used.
3. Using VSS on Cisco 6500 Switch. Two switches can be used.
HTH,
Toshi
